koni yelllow perch settings
Old Dec 26, 2006 | 02:14 AM
ieatrice's Avatar
Default koni yelllow perch settings
i searched and haven't found an answer. i got GC coilovers and koni yellows for xmas. now, the front shocks has 2 perches and the rears have 3. which perch should i set it on?
Old Dec 26, 2006 | 03:32 AM
G402's Avatar
Default Re: koni yelllow perch settings (bolsaman)
Standard setting in front is the heighest perch, back is the middle.
I put them both on the lowest.
Old Dec 26, 2006 | 03:50 AM
instrument's Avatar
never knew there were standard settings
it depends on if you got them for show or if you actually want your car to handle better.
if you just want the ability to dump your car the lowest possible then just put them on the lowest.
and if you have gc's you dont actually use the physical "perch" just the metal ring.
i put both of mine on the highest perch, since gc's don't have a "helper" spring, it annoys me that when the suspension isn't under load the spring just moves freely.
Old Dec 27, 2006 | 01:16 AM
ieatrice's Avatar
i want my car to handle better.. so should i put the fronts on the top perch and the rears on the middle perch?
Old Dec 27, 2006 | 06:46 AM
instrument's Avatar
you have a coil over, you can adjust the height of the spring using your coil over.
the "perch setting" isn't going to effect your handling as far as i'm aware, it'll allow you to make the car lower or higher then the normal adjustability allowed by the coilover alone.
Old Dec 27, 2006 | 07:02 AM
ieatrice's Avatar
Default Re: (instrument)
oh ok, awesome! thanks for reply
xsquizet
Suspension & Brakes
Jul 30, 2009 07:54 PM
hpimichael02
Aug 27, 2008 05:25 AM
jli18
Suspension & Brakes
51
Nov 30, 2005 06:04 AM
Junkyard2000
Suspension & Brakes
May 28, 2005 10:32 AM
mingbling96
May 1, 2005 07:43 PM
