iat reading????
Old Dec 25, 2006 | 11:16 PM
dbiker207's Avatar
Default iat reading????
i have a b18c1 in a crx, im using a b16a1 head and a obd0 pr3 ecu. the problem is that when i datalog i get a reading on the iat of 87-88 deg ferenhiet all of the time. i tried replacing the sensor, with a used one, and i still get the same reading. when i disconnect it i get disconnected from my logger but i dont throw a code and my idle starts surging. so i think it is seeing the iat but not sure. i also checked continuity from the connector to the shock tower and from the shock tower to the ecu pin c5 and c12. any ideas?
Old Dec 25, 2006 | 11:46 PM
abnaasefmb's Avatar
Default Re: iat reading???? (dbiker207)
what are you using to log? mine goes from 80s to 120s depending on driving conditions
Old Dec 26, 2006 | 03:53 AM
92civicfreak's Avatar
check the wires... one may be corrodded in one place... haha good luck w/ that one
Old Dec 26, 2006 | 07:31 AM
dbiker207's Avatar
Default Re: iat reading???? (abnaasefmb)
using bre to log
Old Dec 26, 2006 | 08:40 AM
89EF_Turbo's Avatar
The sensor has a 0-5v range...try testing the sensor off the intake manifold but still plugged in to the harness. Hold a low heat source under the sensor and see if the reading and voltage changes. If the motor has been turbo'd, you'll see some higher intake temps anyway. I run BRE on my setup, and I used to sit around 90F. on average boosted, and slightly higher during the summer. I haven't datalogged n/a yet though, so I don't know where the values sit at.
tgmueller
Apr 29, 2013 10:42 PM
dbiker207
Dec 24, 2006 05:04 PM
youngvedder
Mar 19, 2004 10:28 AM
kell211
Oct 5, 2003 05:59 AM
