CEL - New York Inspection - Auto Manual Swap
Old Dec 25, 2006 | 08:21 PM
93civic2005's Avatar
Default CEL - New York Inspection - Auto Manual Swap
I'm planning on the auto-manual swap for my 93 Civic. I know that I'll be getting a CEL afterwards unless I switch the ECU or modify my current auto one (verify this as correct?). However, I need to pass inspection fairly soon afterwards in New York. Can someone tell me if the CEL from the swap will affect my passing the inspection? I don't know exactly how OBDII works, but I figure a CEL due to my transmission shouldn't have anything to do with emissions?
Old Dec 25, 2006 | 08:24 PM
2wheelhunter's Avatar
Default Re: CEL - New York Inspection - Auto Manual Swap (93civic2005)
NY doesnt care wether the CEL is on in a 93 civic, it is not obd2 so ur set! good luck!
Old Dec 26, 2006 | 06:15 AM
Default Re: CEL - New York Inspection - Auto Manual Swap (2wheelhunter)
Thanks man. That's the best news I've had this week.
Old Dec 26, 2006 | 08:40 AM
RC000E's Avatar
Dude, just eliminate the problem. Converting an ecu to manual is a cakewalk. No reason someone couldn't do it for you for cheap with a 1 day turnaround time. It takes me all of 10-15 minutes to convert one.
Send the ecu out the day before doing your auto to manual conversion...it'll be back before you know it. Xenocron is in NJ if you want someone reputable to handle your ecu versus someone that doesn't have a storefront.
Modified by RC000E at 9:59 AM 12/26/2006
Old Dec 26, 2006 | 07:00 PM
Default Re: CEL - New York Inspection - Auto Manual Swap (RC000E)
I've seen a thread or two here on Honda-tech about converting the ECU. It's seems like basically a resistor removal or a resistor "moval". Is it really that easy? If so I'd like to do it.
Old Dec 27, 2006 | 04:26 AM
RC000E's Avatar
Remove RP17....leave that opened, then remove RP18 and put a jumper in its place. Simple as that bro.
The RP bundle is on the opposite side of the ecu from where the plugs are to connect it to the car. If your facing the ecu with the top cover off, the grey plugs are on your left, the RP bundle is on the very lower right of the ecu.
Old Dec 27, 2006 | 06:38 PM
Thanks for the help. Sounds like something I can handle for sure.
Old Dec 27, 2006 | 09:32 PM
RC000E's Avatar
Old Dec 27, 2006 | 09:49 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2wheelhunter &raquo;</TD></TR><TR><TD CLASS="quote">NY doesnt care wether the CEL is on in a 93 civic, it is not obd2 so ur set! good luck!</TD></TR></TABLE>
Most definitely not.
CEL's FTW !!!
Antonio325jdm
15
Dec 23, 2015 01:01 PM
max_man4945
May 21, 2010 09:26 PM
jserman
Feb 20, 2007 11:54 PM
99CivicSiBrian
Apr 10, 2006 01:47 PM
D_TY3
Dec 12, 2003 04:43 AM
