vtec not kicking over
Old Dec 25, 2006 | 06:26 PM
hatch b16a guy's Avatar
Default vtec not kicking over
Ok I have a 92 cx hatch that is already wired for vtec. I had to do a head swap another b17a head and drop it in and plug it up and i have no vtec? I checked the solenoid and it kicked over with 12volts. Should I just run the two wires to my ecu instead of messing around with it ?
Old Dec 25, 2006 | 08:07 PM
ilovemysedan's Avatar
Default Re: vtec not kicking over (hatch b16a guy)
Easy way always isnt the right one....I'd look more into it and see if you can find any other flaws in the system....
Old Dec 25, 2006 | 09:29 PM
turbosol_16's Avatar
Default Re: vtec not kicking over (ilovemysedan)
check to see how thick your oil is..... if its loaded with fuel the oil is to thin and low oil pressure will result in ...no vtec
i would run atleast 10w30 and check to see if your oil pressure sensor at the solenoid is reading properly
Old Dec 30, 2006 | 07:00 AM
Default Re: vtec not kicking over (turbosol_16)
Ok the solinoed is kicking over when i run it to a 12v. Another thing is that i guess you are supposed to test it with a muiltermeter and if it is not giving 14-30 ohams then the spool solinoed is need replaced and mine is not even getting four could this be to a bad ground are is it just gone ?
Old Dec 30, 2006 | 08:56 AM
allricedout's Avatar
arent u sopposed to remove the oil jet between cyl. 2 and 3
Old Dec 30, 2006 | 09:13 PM
Default Re: (allricedout)
If it was out of time a little bit would this cause vtec not engauge
tigasin
Nov 14, 2008 11:58 PM
gsr.tuner
Nov 13, 2008 04:50 PM
eat_sleep_ej1
12
Dec 1, 2007 04:43 AM
vtecn8ive
22
Aug 3, 2005 01:06 PM
Cm91h22a
Sep 9, 2003 06:59 PM
