*BAKED* on brake dust
Old Dec 25, 2006 | 04:54 PM
Inline6 Silvia's Avatar
Default *BAKED* on brake dust
i know some people will read the title wrong and suggest dish soap and wash sponge should do the trick for my question but that doesnt work. that is why i emphasized bake. anyways, i have a set of 99-00 SI wheels. they have BAKED on brake dust. meaning it will not just wipe off. does anyone know what i can use to get this **** off? im afraid to start sanding away at it. hopefully there is some type of cleaner i can use to get this **** off
Old Dec 25, 2006 | 04:58 PM
foam's Avatar
did you try a lot of degreaser and a pressure washer?
Old Dec 25, 2006 | 05:02 PM
1SIKEG6's Avatar
peanut butter
Old Dec 25, 2006 | 05:04 PM
macrosshn's Avatar
the son and the heir
Default Re: *BAKED* on brake dust (SoSoLow)
use any sort of wheel cleaner you prefer, or diluted simple green or even dish detergent.
then get yourself some steel wool in the finest grit you can find (usually at the paint section of your local Home Depot) and get to work. go easy as this will take off the clear on your SI wheels. but keep scrubbing and go to a higher grit pad if you feel the finer pad not cutting muster.
enjoy.
Old Dec 25, 2006 | 05:07 PM
schematicsskater13's Avatar
Default Re: *BAKED* on brake dust (macrosshn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by macrosshn &raquo;</TD></TR><TR><TD CLASS="quote">use any sort of wheel cleaner you prefer, or diluted simple green or even dish detergent.
enjoy.</TD></TR></TABLE>
Old Dec 25, 2006 | 05:19 PM
toyomatt84's Avatar
Sanji
Default Re: (1SIKEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SIKEG6 &raquo;</TD></TR><TR><TD CLASS="quote">peanut butter</TD></TR></TABLE>
This does actually work, by the way.
Old Dec 25, 2006 | 07:02 PM
Default Re: (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">This does actually work, by the way. </TD></TR></TABLE>
i know peanut butter has worked on other things but does it really work on baked on brake dust?
Old Dec 25, 2006 | 11:02 PM
Fugly rex's Avatar
Default Re: (SoSoLow)
my friend Korean put peanutbutter on his stock rsx rims which had really thick brake dust on them. The rims were sparkling clean afterwards. He did a lil writeup on it, i'm not sure where it is though.
Old Dec 25, 2006 | 11:10 PM
JayK's Avatar
http://www.p21s.com/products/bis_wc1.html
Mr.Ferio
Jun 11, 2010 10:18 PM
brzrkr
Sep 22, 2008 04:05 PM
Denny
Jul 11, 2003 01:44 AM
py1188
Jun 12, 2003 03:34 PM
Mike P.
16
Jan 17, 2002 06:42 PM
