Trying to decide tb size and injector size, I need knowledgeable people.
Old Dec 25, 2006 | 01:13 PM
sivikvtec's Avatar
Default Trying to decide tb size and injector size, I need knowledgeable people.
I amost have all of the parts needed to get started, I just need alittle help getting the details worked out.
The main components to my setup:
H22A1, 100% stock block
Type-S cams
Euro-R intake manifold
SMSP header, 2.5" exhaust
Air intake of some kind (I have the type-s airbox/k&n filter right now)
Mild port job on the head
I know that the stock injectors are 345cc peak and hold. RC makes either 370 or 550's p&h. Is upgrading to the 370's worth my time, or should I just get the 550's? I will be tuning on hondata s200/p28. I'm not going to use an FPR and will modulate injector pulsing with hondata. Are 550's too big?
I have an ITR throttle body for the intake manifold which is 66mm tapered to 62mm. It appears that the euro-R IM has a 64mm opening. I'm thinking of sending them to maxbore to have the tb bored to a 70mm opening, tapering to 65mm port matched to the IM. Does this sound too aggressive for my setup?
Any informed help would be great, thanks guys.
Old Dec 25, 2006 | 04:50 PM
98vtec's Avatar
moderator emeritus
Default Re: Trying to decide tb size and injector size, I need knowledgeable people. (sivikvtec)
doesnt sound too aggressive at all actually. I'd opt for a 70mm throttle plate tho and get a better intake solution. I really like my BPi intake. The h22 craves some intake so IMO about the throttle, go big or go home.
550's are huge. 345cc should be plenty big for such a mild build.
8_6 luder
Jun 15, 2008 02:12 PM
1.9crxNA
Oct 19, 2006 06:46 PM
Cyber ITR
Jun 17, 2006 05:09 AM
96b18c
Apr 21, 2005 10:49 PM
Macine
Feb 10, 2004 08:28 AM
