What would you use to clean the engine bay?
Old Dec 25, 2006 | 10:19 AM
EK9Tune's Avatar
Default What would you use to clean the engine bay?
Well as the topic says, what would you use to clean the engine bay of a car? Also, is there alittle advice what to watch out for? Like where NOT to get water, and such?
Old Dec 25, 2006 | 10:22 AM
balleur's Avatar
i use simple green and this stuff called engine brite
works really good just foams up then i power wash it off
you can get em both from auto zone
Old Dec 25, 2006 | 10:23 AM
s2kdre's Avatar
Default Re: (allmotor-k)
dish soap works great
Old Dec 25, 2006 | 11:31 AM
vtec4lyfe's Avatar
simple clean if you want the grease removed or any other light degreaser, just be sure to cover open electrical issues that may casue problems. Be sure to rinse well or it will leave residue
Old Dec 25, 2006 | 11:40 AM
95jdmdc4's Avatar
simple green ftw!
Old Dec 25, 2006 | 11:42 AM
EK9Tune's Avatar
haha, i have a ton of simple green concentrate under my kitchen counter. i just hope i don't get water anywhere i'm not sopose too get it.
Old Dec 25, 2006 | 12:12 PM
civhatch90's Avatar
i think you have to cover your dizzy, battery and alternator
Old Dec 25, 2006 | 12:28 PM
UCLA.lion's Avatar
I <3 My CB7.
Default Re: (civhatch90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civhatch90 &raquo;</TD></TR><TR><TD CLASS="quote">i think you have to cover your dizzy, battery and alternator</TD></TR></TABLE>
and MSD
Old Dec 25, 2006 | 12:41 PM
EK9Tune's Avatar
Sweet, just what I was looking for! Thanks a bunch guys ;]
Old Dec 25, 2006 | 02:17 PM
ST4TUS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotor-k &raquo;</TD></TR><TR><TD CLASS="quote">i use simple green and this stuff called engine brite
you can get em both from auto zone </TD></TR></TABLE>
x2 minus the pressurewash. Engine brite works real well (make sure you wash the underside of the hood and let dry while it is still up or it will dirty the bay again)
Old Dec 25, 2006 | 02:31 PM
93blackcivic's Avatar
Easy way!
Use brake parts cleaner to get rid of the extra grime etc., use engine degreaser and wash with high power water and towel.
Finish with tire shine to make next clean up easier.
EK9Tune's Avatar
Ahh, great. I'll keep all that in mind =]
Old Dec 25, 2006 | 02:44 PM
bart2546's Avatar
Default Re: (EK9Tune)
Brake cleaner FTW.
Old Dec 25, 2006 | 03:07 PM
mugenracer's Avatar
When i got my car the engine bay was filthy, with baked in dirt as i'd say it had never ever been cleaned. I used STP tire foam, sprayed it everywhere and let it settle, then got a coarse brush and clean in around everything. Then sprayed some more tire foam about and wiped it all down with a damp cloth. Came up pretty good.
Old Dec 25, 2006 | 03:42 PM
EK9Tune's Avatar
It came out pretty damn good. Did you just shoot it around anywhere? Or you actually covered things up too?
Dude, your header covers are extremely dirty LOL! That's all I noticed, it went from grey to pitch black.
Old Dec 25, 2006 | 03:55 PM
junkyard racer's Avatar
I cleaned engine bays alll through my high school days.
1. on a COOL/COLD engine (cool enough you can put your hand on the valve cover and block and leave it there) spray EVERYTHING down with simple green. Get the hood as well. I always deluted simple green. One bottle from the store made 2 bottles, and it worked the exact same, especially when using a power washer.
2. let the simple green sit for a few min.
3. spray the hell out of it with a powerwasher. I never covered up anything, I would just not hit certain things directly, fuse box, and the connecting points of the wire harness. Just dont hit that directly. Make sure you spray it until you see no more bubbles or any signs of soap. Its going to take quite a while...and soap will sit everywhere. Make sure that you spray everywhere. Start at the hood....(water runs down...dee de dee)
5. if you have the capabilities, take your blower and stick it in a airhose and blow dry everything that way. if not, towel it dry.
6. if you want your hoses and such to be shiny, tire gloss will do the trick.
Hope this helps someone
Old Dec 25, 2006 | 04:05 PM
stealth_bb6's Avatar
Default Re: (junkyard racer)
my dad actually has a power washer, but you guys actually powerwash the engine? like spray the **** out of the engine bay? man that sounds like it would do damage no?
Old Dec 25, 2006 | 04:24 PM
Default Re: (stealth_bb6)
nope. done it many many many times. out of all of the times I have done it, only had a problem once. a little water got down in the sparkplugs...only problem I ever had, and just that one time. I pulled them out, dried em off...stuck em back in, took a sec to fire it up...ran a little rough and no problems since.
I dont even wanna begin to think about how many engine bays ive detailed.
Old Dec 25, 2006 | 04:29 PM
gabebauman's Avatar
Simple Green + Garden Hose + Towel/Rags = Clean Engine Bay for Me
Old Dec 25, 2006 | 04:49 PM
.1type.'s Avatar
Default Re: (gabebauman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman &raquo;</TD></TR><TR><TD CLASS="quote">Simple Green + Garden Hose + Towel/Rags = Clean Engine Bay for Me </TD></TR></TABLE>
X2 works perfect...
Old Dec 25, 2006 | 06:02 PM
matt_shaban's Avatar
Default Re: (.1type.)
simple green and/or Purple Power degreaser
Old Dec 25, 2006 | 06:15 PM
EGRhatch's Avatar
Default Re: (matt_shaban)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt_shaban &raquo;</TD></TR><TR><TD CLASS="quote">simple green and/or Purple Power degreaser </TD></TR></TABLE>
X eleventy Billion
NOTE: <FONT COLOR="red"> I've sprayed the tireshine/WD-40 and after a few days it will start to collect dust and get "dirty" again, if you don't spray wd-40 or tireshine I've had them stay clean for about 2-months before it started to look "Dirty" again..</FONT>
Old Dec 25, 2006 | 06:23 PM
EK9Tune's Avatar
hehe. you read my mind ;] the only thing im worried about is getting water in places it shouldn't get lol.
Old Dec 25, 2006 | 06:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK9Tune &raquo;</TD></TR><TR><TD CLASS="quote">hehe. you read my mind ;] the only thing im worried about is getting water in places it shouldn't get lol.</TD></TR></TABLE>
plastic bags+rubber bands= instant waterproof concoction
Old Dec 25, 2006 | 06:42 PM
rino924's Avatar
White Trash Wish Cash
Community Builder
Community Influencer
plastic bags+rubber bands= instant waterproof concoction </TD></TR></TABLE>
agreed. just dont certain things directly, such as fuse box, air filter, and harness connections, etc. For example, if is pouring rain, stuff is designed to get wet, so just keep that in mind
