2 alternators in 3 days
Old Dec 25, 2006 | 08:57 AM
haroldthefly91crx's Avatar
Default 2 alternators in 3 days
my first one from napa didnt work at all and the one i have now only worked for like a day, now my check battery light is on and i cant figure ot what the hell is wrong
Old Dec 25, 2006 | 10:07 AM
B16-CRX's Avatar
make sure the battery cables are tight. my bro had a prob like that.
Old Dec 25, 2006 | 10:09 AM
Default Re: (B16-CRX)
did that, i actually redid my cables, problem persists
Old Dec 25, 2006 | 10:23 AM
91civicEX's Avatar
Default Re: (haroldthefly91crx)
get a voltmeter and check the wht/blu wire at the alternator. it should have 12 volts with the engine running. also check voltage at the battery with the engine running
Old Dec 25, 2006 | 10:52 AM
Default Re: (91civicEX)
what does it mean if i dont hjave power at that wire?
Old Dec 26, 2006 | 05:29 PM
91civicEX's Avatar
i would say that means your alternator is bad. now why does the alternator keep going bad. is the battery super low? maybe there is resistance in the alt out cable and the alt is constantly overcharging. i dont know man. glad its not my car. check the battery
no power at the white/blu wire means that the regulator is sensing a problem with the alternator and is grounding the charge light causing it to light. if the regulator doesnt sense a problem it gives that wire 12v and the bulb has 12v on both sides causing it to not light.
Old Dec 26, 2006 | 05:41 PM
PINKS's Avatar
I want a CRX tattoed on my butt
are 92 -95 civic alternators the same? do they bolt up
Old Dec 26, 2006 | 05:46 PM
Crx Jimmy's Avatar
Default Re: (PINKS)
I know obd1 alternators have the same plug as obdo, as the mounting points I believe its the same but you might have to switch the pulley I think the obd1's had 4 rib belts, some obd0' had 3 rib belts
Old Dec 26, 2006 | 07:35 PM
B6tizzleHatch's Avatar
Default Re: (Crx Jimmy)
ive had mad alternator problems in the past, check grounds, fuses, belt tension, if its the correct belt, triple check all connections... THEN if that doesnt work, drink some beers and try again tommorow
fix_my_car
Oct 10, 2010 06:08 PM
stockk
14
Aug 27, 2009 11:39 AM
damnthesenames
Nov 27, 2006 02:22 PM
Bc1r6x
Jul 18, 2006 04:58 PM
StatGSR
Jan 20, 2004 06:02 PM
