rebuild prices?
Old Dec 25, 2006 | 08:33 AM
rsdriver17's Avatar
Default rebuild prices?
i have just takin my b18a1 out of my integra so i can get it rebuild and whatnot. im lookin to do an oem build, head and bottom end. just to freshin it up for my low boost project. iv been looking but i want see whatother people who have did it and paid
Old Dec 26, 2006 | 08:42 AM
b18sihatch's Avatar
Default Re: rebuild prices? (rsdriver17)
machine work kills, that is where it gets expendsive if you plan on doing alot of things right. there are also alot of machining steps you can take for your motor.
like to name a few
hot tank head and block
hone block
bore block (if needed)
deck block
knife edge crankshaft
line bore block journals if needed
Micoropolish crankshaft
resurface ie: head,flywheel ect
there is ALOT of things that can be done to get your motor just right, not ALL are need some are a must when rebuilding a motor some arent. but machine work can run you a good ammount of money.
so can assembly and with honda motors assembly is something that needs to be done to the slight precision or else everything wont work correctly and you will find yourself doing it all over again just some thoughts
Old Dec 28, 2006 | 07:35 PM
rsdriver17's Avatar
Default Re: rebuild prices? (b18sihatch)
any price estimates. i talked to a guy and he said it would be 1200 with forged pistons.
Old Dec 29, 2006 | 06:48 AM
b18sihatch's Avatar
shoot, prices vary from different machine shops. some places are more some places charge a little less
Old Dec 29, 2006 | 11:07 AM
delslo93's Avatar
When I got my motor work done on my d16z6 this is what I got done....
Head:
Resurfaced and hot tanked
new valves
port and polish
3 angle valve job
assembly
$650
Bottom end:
Decked
block notched for rods
bored .20 over
cleaned
crank balanced and micropolished
stock flywheel resurfaced
assembly
$455
This was at a local shop but as you can see the head was more than my complete rebuild of the bottom end. Just to give you an idea of what I was charged. THis place charges $50 for flywheel resurface, $20 per cylinder boring, $120 assembly.
Old Dec 29, 2006 | 01:29 PM
trickeng's Avatar
Default Re: rebuild prices? (delslo93)
it will be much cheaper for you to buy a low mileage used B18 vs rebuilding unless you do it yourself.
Old Dec 29, 2006 | 03:37 PM
b18sihatch's Avatar
my machine shop total was 2200.00 but i had way more than the basics done
Old Jan 1, 2007 | 02:56 PM
rsdriver17's Avatar
sweet, thanks
E85B18
Oct 15, 2009 09:05 AM
spooledu24
Oct 20, 2005 04:14 PM
prelude122
Jul 29, 2004 06:44 PM
YellowR2000x2
Sep 10, 2002 11:44 AM
