Have floor harness, possible to use only P/W stuff?
Ugh...
I suppose I should have done more research when I had the car stripped.
I have everything I need for an OEM power window conversion, including a new floor harness.
Sadly, I spent the last 4 months doing a completely **** sound deadenning project. I **JUST** got everything back together, and the thought of pulling it all apart and ripping up parts of the mat to get at the entire floor harness makes me want to cry.
Has anyone JUST used the power window portion of the harness? Does anyone know if they are all tied into a relay or something where you can't just separate it out?
All I want to do is have factory connectors that plug into the door harnesses, run under the dash from both doors to the fuse box. THATS IT. No rear wiper bs, or fuel pump, or anything like that.
Can anyone help?
Thanks!
Can anyone help?
Thanks!
ultra721
Jun 8, 2010 05:24 PM
mikhsoj's ep3-05si
Jul 23, 2008 02:31 PM
