driveshaft removal
Old Dec 25, 2006 | 06:28 AM
gursh d's Avatar
Default driveshaft removal
i broke the axle nuts but to remove the actual axles from the tranny do i just pull them out? is there a certain process to removing them after the axle nut is off or do i just pull em out? thanks
Old Dec 25, 2006 | 07:00 AM
keepitngga1's Avatar
Default Re: driveshaft removal (91.crx.si)
jus pull them out,u might need to use a big flat head to pry it out a bit..but it should jus come out when u pull it
Old Dec 25, 2006 | 09:37 AM
extensioncordy's Avatar
if u just pull it. it may come apart. so if you plan on reusing these axles pry with a flat head.
Old Dec 25, 2006 | 12:07 PM
gospeedgo1's Avatar
Default Re: (extensioncordy)
search the FAQs, there is a guide for removing axles, a couple of them actually.
Old Dec 26, 2006 | 10:03 PM
Default Re: (gospeedgo1)
(correction) ppryfrom the solid part that is close to the tranny..that way u dont pull the boot apart
Old Dec 26, 2006 | 10:31 PM
crawfo661's Avatar
Default Re: (keepitngga1)
unbolt upper ball joint to swing spindle down for clearance, unbolt and remove suspension fork, otherwise you can't pul the axle out in one piece, press wheel side of axle out of the spindle, pry with a prybar next to trans to pop loose, don't get scared, yes fluid is suposed to come out when removed, auto or manual it will do this
Old Dec 27, 2006 | 07:15 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91.crx.si &raquo;</TD></TR><TR><TD CLASS="quote">i broke the axle nuts but to remove the actual axles from the tranny do i just pull them out? is there a certain process to removing them after the axle nut is off or do i just pull em out? thanks</TD></TR></TABLE>
I used a pry bar, very easy to get them out with it.
ugandaHonda97
Dec 15, 2010 12:59 PM
sony224422
Jul 7, 2007 03:29 PM
Passaudi1.8t
Jan 13, 2004 10:01 PM
projecthybrid04
Sep 26, 2002 06:38 AM
Lei Siew Long
Aug 14, 2001 11:55 AM
