motor mount inserts- anybody have measureable benefits?
Old Dec 25, 2006 | 04:58 AM
vladd's Avatar
Default motor mount inserts- anybody have measureable benefits?
i'm almost done installing my turbo in the gsr, and i have the urethane motor mount inserts. im curious- how much, if any, do they actually help in the quarter mile? has anybody run their car before inserts and after for comparison? i'm wondering if they actually have a measureable impact on the time.
Old Dec 25, 2006 | 06:00 AM
Schister66's Avatar
Man U FTW
in for more info.....i too would like to know because i might get a set
Old Dec 25, 2006 | 08:00 AM
vg7z's Avatar
they help with wheelhop, it can lower your 60's, so yes it can affect your 1/4 time. id get a traction bar though, if you really wanted to lower 60's.
i have inserts in my turbo gsr, and i still wheelhop sorta hard
Old Dec 25, 2006 | 08:36 AM
redboost10's Avatar
Default Re: (vg7z)
i have an ek, and what i did was got the inserts for the two top side mounts(oil filled mount on drivers side and the top tranny mount. for the back mount, i am using a place racing mount. and then for the two bottom side mounts, i filled them with window weld. that things is pretty solid
Old Dec 25, 2006 | 09:48 AM
DRAGLS's Avatar
Default Re: (redboost10)
The only reason why I used the inserts on both my motors was to eliminate
engine movement.
Old Dec 25, 2006 | 09:50 AM
building boost's Avatar
Default Re: (DRAGLS)
i had really bad wheel hop with stock mounts. i broke my driver side integra mounta and ac mount. inserts is a good alternative if you don't want to buy aftermarket mounts.
Old Dec 25, 2006 | 10:02 AM
Kev-turboEJ1's Avatar
Default Re: (building boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAGLS &raquo;</TD></TR><TR><TD CLASS="quote">The only reason why I used the inserts on both my motors was to eliminate
engine movement.</TD></TR></TABLE>
This is the reason why I think I am in need of these inserts too.
Old Dec 25, 2006 | 12:15 PM
Civicman86's Avatar
I dont have much wheel at hop now. Definatly helped and pretty cheap to boot!
Old Dec 25, 2006 | 02:23 PM
redboost10's Avatar
Default Re: (Civicman86)
i went through three of those drivers side oil filled mounts. those things suck. i finally welded on some tabs on the front and back of the mount around the base and put a flat bar across the top of the mount with the stud sticking through. then ran a bolt through each side of the flat bar and taped the two welded on tabs. no movement at all from that mount now.
Speed Infliction
Feb 2, 2007 03:29 PM
TeGGY_LS
Nov 30, 2004 01:05 PM
vtecb20coupe
Jul 13, 2004 08:16 AM
HybridIntegra
Jan 20, 2004 12:10 PM
eddiecut
May 8, 2003 08:35 PM
