exhaust with b series swap
Old Dec 24, 2006 | 08:36 PM
92integracer's Avatar
Default exhaust with b series swap
I have heard that the header on the LS is different lengths than the crx header. I have also heard that the bolt pattern on the headers are different. Is is best to just build a custom exhaust or are there ones that bolt right up without length problems or bolt on issues. I also bought a omni power straight pipe for a crx. Should I have bought one for an integra since I have an LS swap?
Old Dec 24, 2006 | 08:48 PM
89hatcher's Avatar
the header on the LS is much shorter like about 5 inches or so and the flange for the LS is turned. the flange for the LS is bigger than the crx flanges. if i were you i would order the straight pipe from an integra then i would get the exhaust custom made or you could buy a full exhaust system then have an exhaust shop trim fit to make the exhaust system fit. thats what i would do
Old Dec 24, 2006 | 09:00 PM
so the straight pipe for the crx won't work with the DC header for the LS motor?
caragan11
10
Dec 19, 2010 11:17 AM
LS94tegra
Mar 29, 2009 07:57 PM
jefftron
Jan 25, 2007 07:53 PM
vietnogi
May 19, 2005 06:51 AM
SPOONup
Dec 25, 2004 10:42 AM
