ecu problems
Old Dec 24, 2006 | 07:22 PM
red beast's Avatar
Default ecu problems
just swapped a 92 ls motor bolted to a 95 ls tranny in a 96 civic coupe(still using stock harness). bought the hondata s200 installed in a pr3 ecu from some guy. the stock harness wont plug into the ecu what do i need to do ,or i justed wasted my money. also what ecu is that
Old Dec 24, 2006 | 07:27 PM
eg_boi's Avatar
Default Re: ecu problems (red beast)
means the ecu u have with hondata is obd2.
Old Dec 24, 2006 | 08:26 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: ecu problems (Vtec_Dragun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec_Dragun &raquo;</TD></TR><TR><TD CLASS="quote">means the ecu u have with hondata is obd2.</TD></TR></TABLE>
Wrong, it means its most likely OBD0 since PR3s are from 89-91 JDM B16A EF8/9
or 92 JDM Integra B16A EF8/9.
What you can do is buy a conversion harness. I never really heard of one but they might make a OBD2a to OBD0 one, but I'm not 100%
Old Dec 25, 2006 | 02:17 AM
red beast's Avatar
Default Re: ecu problems (SkoundrelUSA)
would it be better to fine the conversion harness,or just swap out the hondata into a obd1 ecu. will i be able to tune and run the car properly with the obd0 ecu,if i can fine the harness
Old Dec 25, 2006 | 06:55 AM
red beast's Avatar
bump
Old Dec 25, 2006 | 08:24 AM
adonis2oo2's Avatar
ok heres the thing the pr3 does come in two obd forms obd1 and obd0 neither of which are good for you beacause thats a vtec computer your gonna wanna go with a obd1 p74 or p75 those are both from a 94-95 integra ls obd1 you can also use a pr4 obd1 from a 92-93 integra .. however either route you are going to need a jumper harness for obd2a to obd1
make sure its an obd2a and NOT AN OBD2B
obd2a came 96-98 and obd2b came 99-01 so be carefull also i have the p74 already chipped with a 8000k revlimit and its a mugen program if you are interested in that let me know in a PM however the conversion harness look on jdmshit.com or any of those sites they are typically 75-100$ shipped
Milab21
Engine Management and Tuning
Jan 14, 2009 06:18 PM
Junglesnake
May 25, 2005 05:04 AM
TerribleOne
Dec 17, 2003 09:40 AM
integranator
Mar 2, 2003 09:45 AM
sydag5
Dec 22, 2002 09:00 AM
