Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
Odyssey ignition switch
Old Dec 24, 2006 | 06:24 PM
GregT's Avatar
Default Odyssey ignition switch
I've read of the problems with keys not being able to be removed fom the ignition switch on other Honda models and that problem seems to be related to the shifter cable adjustment, shift interlock switch or ignition switch going bad. My problem is that today the key won't turn at all. It acts like I put the wrong key in the switch and it won't even turn. We only have one Honda so it isn't the wrong key. It worked fine one time and the next time we tried to start it it happened. Would the same three components be suspect?
Vehicle is an 02 Oddysey
Any thoughts?
Thanks, GregT
Old Dec 24, 2006 | 07:13 PM
YeuEmMaiMai's Avatar
Default Re: Odyssey ignition switch (GregT)
key is worn down. Do you have a spare key? if the spare works, then it is worn key.......
Barf Hat
Oct 9, 2019 05:45 AM
JuneBugDrfter
Nov 30, 2013 07:57 AM
badfish2282
May 15, 2009 08:45 PM
b00sted4dr
Jul 31, 2006 05:00 PM
