obd2 gsr ecu on obd1 h22 swap
Old Dec 24, 2006 | 03:12 PM
rollercosta123's Avatar
Default obd2 gsr ecu on obd1 h22 swap
i have an obd1 h22 swap in my 97 accord not running yet. im going to convert that motor to obd2 and i have a chance to get an obd2 gsr ecu. will this work out with my swap good or not? i can also get an obd1 ecu p13. which do you think is good? any pros or cons? which ecu is best. I heard that the obd2 ecu for prelude dont work except for 96. if you guys know anything please help or even tell me if there are any existing forums about this. thanks....
Old Dec 24, 2006 | 03:41 PM
TheMuffinMan's Avatar
He knows where you live!
Will a b18c1 ecu even work with a h22?
Old Dec 24, 2006 | 03:45 PM
Default Re: (TheMuffinMan)
lol i have no idea im asking
Old Dec 24, 2006 | 03:57 PM
I have heavy doubts it would be compatible, they're completely different platforms, stick with the h22 ecu that correlates with your motor
Old Dec 26, 2006 | 07:42 AM
ok
Old Jan 1, 2007 | 07:55 AM
Default Re: (rollercosta123)
i heard something about this being done. is there anyone with such knowledge of this?
Old Jan 1, 2007 | 09:57 AM
96SIR's Avatar
Why not convert ur car to OBD1 and use a P28 ecu? we don't have emissions in FL
Old Jan 2, 2007 | 01:57 PM
Default Re: (96SIR)
what are the pros and cons between obd1 and 2? i was thinking of converting the motor to obd2 and using a p13.
Old Jan 3, 2007 | 02:15 PM
kulrevon's Avatar
Default Re: (Mr Wonderfull)
if you are going to run obd2 you need an ecu without an imobilizer. the 96 p13 does not have one and is obd2. I would say get an obd2-obd1 harness and run a obd1 p13. and call it a day
Old Jan 3, 2007 | 02:59 PM
Default Re: (kulrevon)
so your saying that i can have obd2 and use the harness to plug in an obd1 ecu?
Old Jan 3, 2007 | 10:40 PM
TOP END MS's Avatar
I have heavy doubts on running an OBDII ecu on an OBDI engine. Get an OBDI ecu if your getting an OBDI engine. b/c you have a 97 Accord .. you will need an OBDII -> OBDI conversion harness. I have a barely used Skunk2 one for sale if you interested.
b17itr
Sep 7, 2009 09:43 AM
tgreene2098
Aug 27, 2009 03:09 PM
