roll cage question
Old Dec 24, 2006 | 01:55 PM
LSVTEC96HB's Avatar
Default roll cage question
I have a pair of CRXs that I use for off roading (seriously). I want to put a roll cage in to make them slightly safer in case of a rollover-(it's already happened twice) I want to make them removable, since it's likely the cage will outlast the car. I plan on cutting the roof off for removal and installation. My question is how much should I expect to pay to have one made or is there a sufficient bolt in prefab cage available?
Old Dec 25, 2006 | 08:32 AM
D1SKOOLBUS's Avatar
Default Re: roll cage question (LSVTEC96HB)
Usually you can find a used autopower 6 pt cage pretty cheap. ebay is always a good place to check. i had a autopower in my ef. it made a very noticable difference. what kind of offroading are we alking about ???
Old Dec 25, 2006 | 05:44 PM
LSVTEC96HB's Avatar
Default Re: roll cage question (D1SKOOLBUS)
Thanks for the help. we have a couple of jumps set up at my buddy's house and some trails in the woods we take them on. It is a blast and the cars are unbelievably tough. We have gone through a number of radiators though. We switched to EG radiators and pushed them up out of harms way, but skid plates are definitely on the wish list. I lifted the suspension with stock EK springs and struts, and 28" tires on the front. The fenders are removed and most of the metal is cut or bent out of the way to make room. I relocated the batteries to the back as well.
Old Dec 29, 2006 | 09:02 PM
D1SKOOLBUS's Avatar
That actually sounds pretty cool. you ever check out that issue about a year or two ago in sport compact with the yellow ralley ef? its a sweet little car, they said it actually placed well in its class also. you have any pics of your cars? maybe some action shots?
Old Dec 29, 2006 | 09:16 PM
Dann6968's Avatar
I cant help you with your roll cage question but could you post some pics of your ride?
Old Dec 31, 2006 | 03:01 PM
dohcdelsol's Avatar
check with the h-t sponcer but a buddy of mine was able to order a S&W cage for 169 shipped. they are also located in Pa so not alot of time with shipping.
great quality cage too
Old Jan 4, 2007 | 05:56 PM
boostedblkef's Avatar
Default Re: roll cage question (dohcdelsol)
oh no save the rex's
Old Jan 4, 2007 | 06:03 PM
Bailhatch's Avatar
Default Re: roll cage question (boostedblkef)
i wouldnt make a cage you plan to use often removable. just cut it out when the car is wrecked
neonkid
Sep 12, 2012 07:59 PM
NorCalTrackster
27
Dec 1, 2006 11:59 AM
abda53
Suspension & Brakes
Feb 9, 2006 10:04 PM
6ghatch
25
Dec 23, 2003 10:58 PM
275Performance
May 1, 2003 02:43 PM
