RPM going nuts, need help
Old Dec 24, 2006 | 08:14 AM
eddie31003's Avatar
Default RPM going nuts, need help
I have a 95 accord 6cly and the tach on my car doesn't work right. It will work fine for about 20 min. then it goes back and forth crazy.... and while i'm on the express and i'm doing 60mph and the needle on the tach goes back and forth so does the car.. It gives a jerk....need help..Thnx
Old Dec 24, 2006 | 10:23 AM
hondadude's Avatar
Default Re: RPM going nuts, need help (eddie31003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddie31003 &raquo;</TD></TR><TR><TD CLASS="quote"> It gives a jerk</TD></TR></TABLE>
The engine stumbles??
Usually a crazy tach is a sign of a shorting coil or an ignitor heading south
Old Dec 24, 2006 | 04:12 PM
aZnAcCoRd02's Avatar
Default Re: RPM going nuts, need help (hondadude)
new ignition coil.... should be under warranty still I just had mine replaced a month ago and everything is fine now...
Old Dec 28, 2006 | 09:43 AM
eddie31003's Avatar
im not sure if its the motor that malfunctions or the trans. im going to try the ignition coil and tell you what happens.
Old Jan 12, 2007 | 07:40 AM
eddie31003's Avatar
Thanks for the help aZnAcCoRd02 you are the shiznit. problem solved.
Old Jan 12, 2007 | 12:01 PM
CBL9's Avatar
It should have no effect on the functionality of the car. It is simply a loss of continuity in the coil on the 95-97 V6 Accords. Ours has been doing it for years.
It is under warentty? I never heard that, is there a TSB about it that Honda will fix it for free?
Old Jan 13, 2007 | 06:23 PM
hondadude's Avatar
Default Re: (eddie31003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddie31003 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the help aZnAcCoRd02 you are the shiznit. problem solved.</TD></TR></TABLE>
sorrule
Jun 28, 2007 04:31 PM
SpoolnG2
Aug 3, 2004 11:43 AM
jweller
Oct 2, 2003 05:53 AM
Confuc1ous
Aug 23, 2003 11:17 PM
Boughetto
Aug 5, 2002 04:57 PM
