clearance issues w/gt35r does anybody know the dimensions of it?
Old Dec 24, 2006 | 06:54 AM
gogunkergorilla's Avatar
Default clearance issues w/gt35r does anybody know the dimensions of it?
i want to upgrade from my t3/t04e 56trim to a gt3582r. right now there is only about 1.5 inches clearance from the compressor to the radiator. does anybody how much bigger a gt35r will be? need this dimension...
is a .63 housing the same size as a .82 externally? only the inside and exhaust port are bigger right?
Old Dec 24, 2006 | 01:55 PM
TheShodan's Avatar
Moderator
Here you are. You may have a different A/R turbine housing. Check with your current one to compare if you are using the same A/R on your new turbo. You may need to post pics of your engine bay to get better opinions of what you're trying to accomplish
Old Dec 24, 2006 | 04:38 PM
Default Re: (TheShodan)
i've seen that picture somewhere...they use the same one for the gt30 also so it probably not to scale. i need the diameter of the compressor housing like my picture(bad picture sorry, its supposed to be a side view of a compressor housing)...thats the angle its going to be in the car though.
my problem is, if i just swap my t3/t04e .63ar for a gt35r .82ar on my setup how much closer will it be to the radiator if its about 1.5 inches from it now. with the engine rotating slightly, i'm worried it will be too close and hit. i'll post some pics tomorrow.
i'm using stock mounts by the way...
crvtkllr
Oct 22, 2006 06:25 PM
Sunlight
Apr 6, 2005 10:04 AM
LudeyKrus
Mar 12, 2004 01:02 PM
jinsokuSI
May 14, 2002 10:19 AM
