What is the biggest cam i can run on a stock gsr head reving to 8000 rpm ???
i'm shopping for a cams for my b16b block gsr head setup
what can i run on stock valve springs?
biggest cam with not to much risk
thanks
thanks
itr cams.
I will be running itr cams on my stock gsr valvetrain with itr pistons. I willpost dyno results when its all done
many have said that they like the power from regular skunk 2 stage 2 cams but they keep the rev limit at 8000 on a stock gsr head
has anyone tried these cams on a stock gsr head ???
It's not the revs, but the lift from the cams that cause binding (valve float)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c »</TD></TR><TR><TD CLASS="quote">It's not the revs, but the lift from the cams that cause binding (valve float)</TD></TR></TABLE>
get some buddy club spec3 or skunk2 stage 1. Little wierd motor combo. You should instead invest in a GSR crank
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg4life1202 »</TD></TR><TR><TD CLASS="quote">many have said that they like the power from regular skunk 2 stage 2 cams but they keep the rev limit at 8000 on a stock gsr head
i have also heard of people running stage 2s with stock valve train, i have thought about trying it myself but never have
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxb18c1 »</TD></TR><TR><TD CLASS="quote">
i have also heard of people running stage 2s with stock valve train</TD></TR></TABLE>
not for long.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">Ummmm, S2S2 + stock valvetrain = boom. </TD></TR></TABLE>
Nah, not boom but "My car just shut off"
not for long.
If your only turning 8k max with a 1.6l I wouldn't go any bigger than the itr cams.The gsr cams may make the best overall power unless your always driving from 6-8k all the time.
spoonhatchblack
Oct 5, 2007 11:10 PM
