went to the track today and need some input
Well I went to the track today (Sacramento Raceway) and got a couple of passes in.
Best pass was:
reaction=.482
60ft=1.960
1/4=13.700 @96.939
set up is a jdm b16 completely stock head and block no work done to either.Running ITR manifold with a DC 4-2-1 header and GSR tranny...ran a velocity stack out the headlight and ran open header.Rolling on bogarts all around with 22x8x13 in the front and 22x3.5x15 in the rears.All in a 92 civic hatch si gutted of course.
I was just wondering why is my trap slower that what i ran back in october when i first swapped the motor which was 13.942 @ 97.045 that run was made on mickey thompsons 20x8x14's.
as of January 14th i ran a personal best of 13.415 with a 1.7 60ft still internally stock motor and all motor at that
Modified by allmotaeg6 at 5:46 PM 12/24/2006
Modified by allmotaeg6 at 7:20 PM 1/15/2007
Best pass was:
reaction=.482
60ft=1.960
1/4=13.700 @96.939
other runs
13.880 @95.794 rt=.258 60' 1.929
13.927@96.327 rt=.201 60' 2.032
13.993@96.438 rt=.196 60' 2.074
13.887@96.078 rt=.332 60' 1.986
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotaeg6 »</TD></TR><TR><TD CLASS="quote">Well I went to the track today (Sacramento Raceway) and got a couple of passes in.
Best pass was:
reaction=.482
60ft=1.960
1/4=13.700 @96.939
Your honestly asking why your trap is a tenth of a mile per hour slower? Come on. Track conditions, weather, etc could EASILY show a tenth of a mile per hour difference.
I never went out there on sat. Is it a good time to run? Expensive? Lots of people?
My best time to date is a 14.0 @ 102mph with my new setup, full interior and all. I've never run slicks though so my best 60 is a 2.3, lol. Your times are very good for the traps you are showing. I'd be happy.
Best pass was:
reaction=.482
60ft=1.960
1/4=13.700 @96.939
Very strong for a stock b16 in a 92 hatch. Most people here in Orlando area only manage 14.5-14.3 with the same mods.
Have you ran the car without the velocity stack before and have you ran it with the exhuast hooked up?
Either way Badass times. Keep us updated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">Your honestly asking why your trap is a tenth of a mile per hour slower? Come on. Track conditions, weather, etc could EASILY show a tenth of a mile per hour difference.
My best time to date is a 14.0 @ 102mph with my new setup, full interior and all. I've never run slicks though so my best 60 is a 2.3, lol. Your times are very good for the traps you are showing. I'd be happy. </TD></TR></TABLE>
yea i guess it was just tripping me out i should be happy...
As far as coming out on a saturday, its cool not very many people so you can get some good runs in and try out new things...It's $50 to race and they are not as strict as they are at actual events
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LDS »</TD></TR><TR><TD CLASS="quote">Very strong for a stock b16 in a 92 hatch. Most people here in Orlando area only manage 14.5-14.3 with the same mods.
Either way Badass times. Keep us updated.</TD></TR></TABLE>
with out the stack and exhaust hooked up i'm hitting 14.0
I agree, you can't expect to run the same times every trip to the track. One thing for sure is you should be doing alot better 60ft's. You gotta launch it harder if your going to justify the $1000 bogart slick package because your in drag radial range right now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">I agree, you can't expect to run the same times every trip to the track. One thing for sure is you should be doing alot better 60ft's. You gotta launch it harder if your going to justify the $1000 bogart slick package because your in drag radial range right now.</TD></TR></TABLE>
i was lauching at 7000 preloading the trans...slicks were at 10psi.Should i go lower on the psi and and launch a little higher?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotaeg6 »</TD></TR><TR><TD CLASS="quote">i was lauching at 7000 preloading the trans...slicks were at 10psi.Should i go lower on the psi and and launch a little higher?</TD></TR></TABLE>
Were you bogging or spinning? If you were spinning drop the pressure a little, if you bogged then started to go raise the RPM and if that doesn't work raise the slick pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">Were you bogging or spinning? If you were spinning drop the pressure a little, if you bogged then started to go raise the RPM and if that doesn't work raise the slick pressure.</TD></TR></TABLE>
at first i was spinning i was at 12 psi.Lowered it to 10 psi then it started to bog and then go so i launched a little higher and that was when i hit the 13.7
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16why8 »</TD></TR><TR><TD CLASS="quote">nice time for stock b16 on eg.
hows the weatehr yesterday.im going jan.1 for bracket racing.</TD></TR></TABLE>
weather was really good yesterday. if i remember right it was upper 60's...yea i think some friends and i will be going back next saturday to get some more runs in to dial in for winter warm ups on the 14th of january
hows the weatehr yesterday.im going jan.1 for bracket racing.</TD></TR></TABLE>weather was really good yesterday. if i remember right it was upper 60's...yea i think some friends and i will be going back next saturday to get some more runs in to dial in for winter warm ups on the 14th of january
play with tire pressure bro and your launch find the right combo and call it a day
Modified by SiKnezzALLmotor at 7:32 PM 12/31/2006
Good time's.
FYI Reaction times have no bearing on your overall time. It's simply how fast you react to the light. The timing doesnt start until you have crossed the second stage beem.
Generally your 60ft's will have some bearing over your MPH. A lower 60ft usually nets a lower MPH and vice versa. Your times are so close that it is simply due to your driving half and end track.
Mitch
Mitch
Gearing....your tires are too big for the power you are making. You had the right setup with the 20 inch slicks for your power. With the 20s you should be able to cut a low 1.8 and run 1-2 mph more.
That's my opinion. I don't think you need to move up to a 22 until you are above 210whp...at least.
My friends stock B16 all motor EG ran 13.59 @ 101 with a 1.89 60. It had the stock clutch and ecu. He launched on the limiter which was at 8200 rpm and shifted a 8000 rpm. He used M & H 22x8.0-13 @ 9.0 psi. The engine put out 151 whp and 115 trq on the dyno. The stock clutch let go after 2 races so an ACT 6 puck was installed, the car went a little faster it ran a 13.53 @101. Keep in mind we race in Hawaii were are track is at sea level are corrected altitude is somewhere around 1400 ft.
Your trap speed depends on your 60ft.If your 60ft was a 1.9 for example,THen your speed would be 102.If it was a 1.7 60ft at 97MPH,Then your trap speed would be lower since U hooked up better.Very impressive ET on a stock B16a bro.Good Luck,Darrell
i cant beleive you got those times with a gsr trans. did you finish in third with those 22 inch slicks? it seems like you could gain a lot by switching to a b16 tranny. b16's feel like they dont have enough tourque to effectively use the gsr trans.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TealEG! »</TD></TR><TR><TD CLASS="quote">i cant beleive you got those times with a gsr trans. did you finish in third with those 22 inch slicks? it seems like you could gain a lot by switching to a b16 tranny. b16's feel like they dont have enough tourque to effectively use the gsr trans.</TD></TR></TABLE>
yea i was surprised too...i'll probably be switching to an itr tranny soon but on the 14th will be the last time i race the b16 be cause my other build should be done soon built b20/vtec...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LDS »</TD></TR><TR><TD CLASS="quote">Been back to the track?? I cant wait to hear what it goes next. This is on my watched topics.</TD></TR></TABLE>
next week on the 13th and 14th i will head back to the track and see what happens
and ill have some videos to post up too
update went to the track this past weekend...new best on the stock b16 13.415 with a 1.7 60ft...pretty damn happy! will have a video up soon
