vtec not engaging
Old Dec 23, 2006 | 06:38 PM
ken2830's Avatar
Default vtec not engaging
what's up.I got an h22 and vtec won't engage. I have a check engine and wen I jump it,it gives 1 long blink. that code I think is an o2 sensor but I have a new one installed.I also don't have my iacv connected but it doesn't give me a code for that.if nothing works I was thinking of controlling vtec manually by a button....any help would be appreciated. otherwise without vtec it still moves but it performs better with it....
Old Dec 23, 2006 | 08:33 PM
zccr-xsi's Avatar
are u low on oil?is your vtec hooked up right?what ecu u useing.as for having a button to engage vtec thats abotu the dumbest thing i seen or heard of.
Old Dec 24, 2006 | 05:47 AM
pcguy760's Avatar
Default Re: vtec not engaging (ken2830)
By engaging VTEC with a button (power directly to the solenoid), you will not get the full performance of it because I do not think the ECU will change the fuel map for VTEC and you will be running on the regular fuel map = poor VTEC performance.
According to Hondata, the ECU has a different fuel map/table for when it engages VTEC. I do not think it will load up this fuel map if you just power up the solenoid...
Any other codes you might be getting? Did you manually test the solenoid?
Old Dec 24, 2006 | 06:44 AM
ken2830's Avatar
Default Re: vtec not engaging (pcguy760)
vtec solenoid works fine.me and my boy tested it out hooking it up directly with two wires and just tapping it reaching a certain rpm..I noticed a big difference but other wise I don't get a cel for nothing else...it would be better to have vtec open wen its suppose to but if I can't get it corrected i'll just have to do the button trick.and only pop vtec wen I have too...
Old Dec 24, 2006 | 07:12 PM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/zerothread?id=1812135
Old Dec 25, 2006 | 05:36 AM
pcguy760's Avatar
Good link Hondapartshero - I need to bookmark that!
Old Dec 25, 2006 | 08:18 AM
rsdriver17's Avatar
Default Re: (pcguy760)
my buddys wasnt working and someone told him the filter on the solenoid maybe clogged, so we took it off and cleaned it with an air hose and it worked fine after that
Old Dec 25, 2006 | 11:08 AM
onepoint6i's Avatar
Default Re: (rsdriver17)
one long blink is code 10 not code 1
nkcalvert09
Jun 11, 2011 10:43 PM
Outsane
Mar 11, 2005 11:22 PM
oday
Oct 21, 2004 04:38 PM
el arbi
Mar 14, 2003 04:03 PM
SOHCMAN
Dec 20, 2002 10:01 PM
