What else do I need?
Old Dec 23, 2006 | 05:52 PM
EX-T's Avatar
Default What else do I need?
I have a '99 Civic EX coupe with a manual transmission. I also have a GReddy 15g td04h turbo kit on it.
I have sitting in my truck a p06 ECU chipped with Crome for VTEC, DSM 450cc injectors and a resistor box. I know I need an OBD1-OBD2b jumper harness. I'm thinking about just selling the resistor box and wiring some 1/4W 10ohm resistors in line with what ever clip I need.
That's what my problem is. Can I go to a junk yard and get any OBD1 injector clips for the DSM 450 and them practically plug and play?
TIA
Old Dec 23, 2006 | 06:36 PM
97spooncivic's Avatar
Default Re: What else do I need? (EX-T)
yes, but if you already have the resistor box why not use it? In line resistors look nasty and a resistor box is actually ment for the application your using it for. Also, i believe you can modify your injector cllips to make them work with the DSM's. if you search i think youll be able to find a thread on it in the archives.
Old Dec 23, 2006 | 06:51 PM
EX-T's Avatar
Default Re: What else do I need? (97spooncivic)
How do I go about using the resistor box for obd2? The guy I got it from was using it in a CRX and he said to unpin the dummy plug on the driver's side but I don't have a dummy plug on the driver's side.
Old Dec 23, 2006 | 07:01 PM
EX-T's Avatar
I got my answer for the injector clips, but what about the resistor box? I have no idea what vehicle it's from but there are 4 red wires and 1 yellow wire coming from the resistor box to a pig tail. Where do each of these wires go?
Old Dec 24, 2006 | 02:39 PM
im not sure, but get a pic of it and post it in the forced induction section and they should be able to help you out. GL
luvmihatch
Sep 22, 2008 07:59 AM
Slow Ek
Sep 2, 2008 04:26 PM
evosix
Jun 4, 2008 06:41 PM
Licensed2Spool
Apr 12, 2003 10:51 AM
