Replacement Parts Assistance (91 CRX Si body, 93 Integra Xsi Engine)
Old Dec 23, 2006 | 05:34 PM
fluxuator's Avatar
Default Replacement Parts Assistance (91 CRX Si body, 93 Integra Xsi Engine)
I have a 91 Honda CRX Si Body with a 92-93 JDM Integra XSi Engine and need to know what would be best to cross reference when using USDM parts?
Specifically I need to know what Axles and Alternators would fit... 95 Honda Del Sol DOHC VTEC? reading through the forums it would seem that the Integra 92-93 GSR Axles would be a perfect match for my setup but would the alternator for that year model also work? Any help or assistance would be great. Please fill in the following...
Axle =
Distributor =
Alternator =
Breaks =
Fuel Filter =
Water Pump =
And any other parts that I might need to replace in the future..
Thanks,
fluxuator
Old Dec 23, 2006 | 11:27 PM
abnaasefmb's Avatar
Default Re: Replacement Parts Assistance (fluxuator)
Your right on the axles. You’ll need to remove the dust rings on the hub end and the dust shields off the back of the hubs.
As for the alternator I’m not sure. the one that came with my swap worked fine. I ordered another obd1 1 engine that that came with a different plug that would need to be repined so I just swapped it for the alt. off my old xsi setup but kept the alt and plug just incase I ever need it.
the rest of the sit just order 94 dohc vtec.
http://www.hondaautomotivepart...gry5=
Old Dec 24, 2006 | 10:15 AM
QuickRexSi21's Avatar
Default Re: Replacement Parts Assistance (abnaasefmb)
GET ER DONE!!!! let me know when you get the parts, ill see if i can roll down and help you out DOGUH!!
Old Dec 25, 2006 | 05:38 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fluxuator &raquo;</TD></TR><TR><TD CLASS="quote">I have a 91 Honda CRX Si Body with a 92-93 JDM Integra XSi Engine and need to know what would be best to cross reference when using USDM parts?</TD></TR></TABLE>
- Axles = '90-93 Integra if you're using the transmission and intermediate shaft from the '92-93 XSi
- Distributor = depends on what OBD system you are running; if OBD-1, use '92-95 Integra GSR or '94-95 del Sol VTEC (distributor stamp is TD-44U or TD-68U)
- Alternator = OBD-1 ('92-95) B-series
- Brakes = '90-91 CRX Si, unless you changed the brakes . . .
- Fuel Filter = '88-91 Civic/CRX, which is probably what you're already using . . .
- Water Pump = any VTEC B-series
In general, most engine parts will be for a '94-95 del Sol VTEC, which had a similar OBD-1 B16A engine.
Old Dec 25, 2006 | 06:23 PM
Crx Jimmy's Avatar
Default Re: Replacement Parts Assistance (Targa250R)
^^^ all items are correct I always ask for del sol DOHC VTEC parts 94-95(except for axles). I have the same motor in my car
Old Dec 26, 2006 | 08:37 AM
fluxuator's Avatar
Default Re: Replacement Parts Assistance (Crx Jimmy)
Thanks Alot!
Old Dec 26, 2006 | 01:24 PM
whats the happs?? did you get er done?
Old Dec 30, 2006 | 05:17 PM
fluxuator's Avatar
Default Re: Replacement Parts Assistance (QuickRexSi21)
Got er Done!
Big thanks to all for assisting with parts info... and big thanks to https://honda-tech.com/zero...age=1 that thread for the balljoint pop method.. omg this was eeeeeeZ
The CRX Lives again!
HereForGoodKnow
Jan 2, 2012 09:42 AM
Toallhisdoom
Apr 7, 2011 11:57 AM
B16afmaxt
Oct 25, 2009 05:07 PM
civichopeful
Oct 13, 2002 03:42 AM
91crxer
Jul 9, 2001 01:54 PM
