Removing exhaust manifold cover
Old Dec 23, 2006 | 07:18 AM
Cluser's Avatar
Default Removing exhaust manifold cover
I decided I wanna remove my exhaust manifold cover, and I got one bolt off, and the other one is SOOO hard, it seems to get tighter as I loosten it. Will I crack my block if I try too hard?
Any suggestions on how to get that screw off?
Thanx in advanced.
Old Dec 23, 2006 | 08:04 AM
Perfectionist's Avatar
Default Re: Removing exhaust manifold cover (Cluser)
Won't crack your block, but it might fracture your exhaust manifold. You could try a penetrating oil. It would help lubricate the threads a bit.
Old Dec 23, 2006 | 08:17 AM
Hawkze_2.3's Avatar
Make sure you have the right size socket and use a long breaker bar. It will come off....one way or another, haha. It might break off in there if it's rusty enough.
Old Dec 23, 2006 | 11:36 AM
street_accord94's Avatar
Use quick, hard pushes on the breaker bar to help minimize the chances of breaking the bolt...or if you have access to an impact wrench try that to back em out.
Old Dec 28, 2006 | 10:49 AM
BoostedH23Accord's Avatar
$20 bucks says it breaks...
Old Dec 28, 2006 | 11:22 AM
Honda4lyf's Avatar
Spray some WD-40 or sumthin, that'll take care of the rust and it should come off easily. Just watch out for fire.
Old Dec 28, 2006 | 03:09 PM
iam7head's Avatar
Default Re: Removing exhaust manifold cover (street_accord94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_accord94 &raquo;</TD></TR><TR><TD CLASS="quote">Use quick, hard pushes on the breaker bar to help minimize the chances of breaking the bolt...or if you have access to an impact wrench try that to back em out.</TD></TR></TABLE>
finally someone with good advice, give it a quick jerk. don't crank it slowly with a long **** breaker bar or the thread will snap/stripped
liquid wrench bolt, let it sit, runs the car and try it while everything is hot
Old Dec 28, 2006 | 04:22 PM
mtnwkr's Avatar
Default Re: Removing exhaust manifold cover (iam7head)
I spun the head off of two of them on my old cd5. They broke off like they were made of cheese.
Old Dec 28, 2006 | 11:39 PM
senor honda's Avatar
After lubing with Blaster, and tapping on the bolt head to "jar" the oil into the threads, I would work it first one way just a little bit (like cutting new threads on a pipe), then back, until I could get one full turn, then back it on out. I haven't had great luck with sudden impacts on rusted-in bolts.
For reassembly, I get generous with "never-sieze" on some brand new STAINLESS
replacement bolts.-Bob
'90crxSI
Sep 14, 2008 05:38 PM
supermotothud
Jun 18, 2008 04:59 PM
Threads
Aug 27, 2004 06:21 AM
civcexcoupeblack
May 3, 2003 09:54 AM
Pat
Jun 21, 2001 08:54 AM
