need help guyz!!!!
i recently built a ls motor with p30 pistons blox intake manifold 404 cams etc. i cant get the damn thing to run. im getting spark but no fuel. the injectors arent spraying. i get fuel pressure to the fuel filter but not to the motor. the injectors are getting power but not grounding out. anybody can help me plz need it soon i want it running
the noid light showed no power i went around and checked all my grounds and there all grounded. im running a chipped computer from pheriable until i get it to a tuner
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nylshatch »</TD></TR><TR><TD CLASS="quote">the noid light showed no power i went around and checked all my grounds and there all grounded. im running a chipped computer from pheriable until i get it to a tuner</TD></TR></TABLE>
ok. check every single thing. see if you injectors are getting ground at the injector clips. but seems like u have narrowed it down to just the injectors. either the ECU is not doing its job, or a connection between the ecu and the injectors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2001B18C1GS-R »</TD></TR><TR><TD CLASS="quote">did you check the fuses under the dash and under the hood also do you hear your fuel pump when the key is in the on postion
very important thing too. i just thought u might have done that.
pythoner
Dec 28, 2006 01:59 AM
harryr34
Jun 7, 2005 01:23 PM
