225/45/17 Tire on 0.5 inch wheel
Old Dec 22, 2006 | 09:28 PM
rathead81's Avatar
Default 225/45/17 Tire on 7.5 width inch wheel
I have a 2001 Accord Coupe, 4 Cyl with Eibach prokit springs on stock shocks.
Im planning on getting wheels that measure 17 x 7.5 w/ +42 offset
I was going to get 205/50/17 tires, but it seems that those tires might be too small for a 7.5 in. wheel.
215 mm tires are a bit offsize from the OE tire, so Im planning on getting 225/45/17 tires.
My question:
Will the tires rub?
Is it a good fit for my wheels size?
Modified by rathead81 at 6:22 PM 12/24/2006
Old Dec 22, 2006 | 11:50 PM
iam7head's Avatar
Default Re: 225/45/17 Tire on 0.5 inch wheel (rathead81)
215 will be a perfect match
Old Dec 22, 2006 | 11:53 PM
SuShiBoiiii's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rathead81 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 2001 Accord Coupe, 4 Cyl with Eibach prokit springs on stock shocks.
My question:
Will the tires rub?
Is it a good fit for my wheels size?</TD></TR></TABLE>
perfect size thats what i runnin no rubbing at all
Old Dec 24, 2006 | 05:33 PM
rathead81's Avatar
Default Re: 225/45/17 Tire on 7.5 width inch wheel (rathead81)
215 is a perfect match?
My OE 195/65/15 tires have a diameter of 25 inches
I believe 215/45/17 tires have a diameter of 24.6 inches
and
225/45/17 tires have a diameter of 25 inches.
Can anyone else give me some more input on wearing 225s with 17 x 7.5 wheels?
Thanks
Old Dec 25, 2006 | 02:23 AM
sorry for confusion but yeah 225 works great on a 5th and 6th gen
Old Dec 25, 2006 | 06:46 AM
89POS's Avatar
Default Re: 225/45/17 Tire on 7.5 width inch wheel (SuShiBoiiii)
im runnin 215/40/17s on my 5th gen acc...no problems at alll. i think my wheels are 17x7.tire sits almost flush w/rim.
Old Dec 25, 2006 | 10:33 AM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rathead81 &raquo;</TD></TR><TR><TD CLASS="quote">215 is a perfect match?
and
Thanks
you need to know the different between mm width, ratio and inches in radius
215 or 225 will mount up but i doubt you will need 225 all around the corner, not to mention the you might rub under extreme load in the corner with 225.
Old Dec 25, 2006 | 10:29 PM
oodie's Avatar
I have 215 40 17 on mine here is a picture fits perfect.
[IMG]http://img185.imageshack.us/img185/8840/sd530024gq4.jpg[/
oodie's Avatar
Default Re: 225/45/17 Tire on 7.5 width inch wheel (oodie)
oops
vandium
May 3, 2010 03:46 PM
mrcrimane
Mar 25, 2003 10:28 PM
MyFirstPrelude
Mar 25, 2002 09:06 AM
SuperRice
Mar 5, 2002 09:18 AM
zojirushi
Jan 15, 2002 03:52 PM
