Extra plug on b16a swap
I cant figure out where a connection on the wiring harness plugs into the motor. There are two wires going to the connection. One of them is blue and the other is black with a yellow stripe. It looks like it should plug into somewhere on the back of the block but i cant seem to find where.
Thankyou
Thankyou
its most likely for the fan switch, you probably have a obd1 or newer motor, the fan switch is on the thermostat housing instead of the back of the block, just need to attach a new plug to those wires for the new sensor on thermo housing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">its most likely for the fan switch, you probably have a obd1 or newer motor, the fan switch is on the thermostat housing instead of the back of the block, just need to attach a new plug to those wires for the new sensor on thermo housing</TD></TR></TABLE>
The motor were using is a JDM B16A OBD0.
Just looked closer, yes there is a 2 pin wire it does not go to anything it was for a fast idle valve on the civic/crx . I almost forgot i just left it there and taped it to the wiring loom so it didnt dangle, there is nowhere on the b16 for it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">what year is the stamp on the head? </TD></TR></TABLE>
Not sure, but im 99% sure the motor is from a 1989 JDM Integra XSI.
VNTEC
Mar 15, 2004 04:50 PM
