need help what should i do!!
Old Dec 22, 2006 | 06:27 PM
exotik4doorcivic's Avatar
Default need help what should i do!!
i have a d16z6 or i guess i should say had.
a couple days ago i broke my timing belt at 3000 rpms
i have a couple options,
*replace the belt and hope for the best
*replace the head, headgasket, and head studs
*replace with a jdm d15b vtec for $500
problem is the d16z6 had 85,000 miles and boosted for 6,000 so the timing belt has never been changed, but i cant get the crankshaft pulley bolt off
i used a impact gun, and a breaker bar, but i still cant get it off, help me out
also if i change out to a d15b, can i use my chipped p28 ecu??
what would you do in my situation
Old Dec 22, 2006 | 06:38 PM
turbodegsi's Avatar
Default Re: need help what should i do!! (exotik4doorcivic)
ok first off are there any bent valves???
if there is valves aren't that expensive..
i would replace the valves, get a bigger cam and new head gasket, etc....
and you would prob. be better off than getting a d15b head..
but find out if there is anything wrong with the head
Old Dec 23, 2006 | 10:42 PM
Default Re: need help what should i do!! (turbodegsi)
UPDATE***
well i got the bolt off and put the belt on, started the car and heard a slight tick,i havent started it in 5 days so it might be the lifters,
i am going to put the belts on tomorrow and let it warm up, hopefully nothing serious went wrong
Old Dec 23, 2006 | 10:48 PM
Striker_1818's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exotik4doorcivic &raquo;</TD></TR><TR><TD CLASS="quote">UPDATE***
Good luck!
Old Dec 24, 2006 | 12:36 PM
UPDATE<U></U>
well i put everything back together and i have no ticking whatsoever
car seems like it needs to be timed on the distributer with a timing gun, but other than that, car rus/drives great!!
i gues i got my christmas presant early
Old Dec 24, 2006 | 12:49 PM
95DxSi-R2
Guest
Posts: n/a
lucky bastard
edfed
Dec 30, 2008 09:19 PM
davesrex
Sep 29, 2007 03:36 PM
CodyC142
15
May 30, 2007 12:18 PM
exotik4doorcivic
Dec 24, 2006 12:40 PM
97gSrkId88
Jul 3, 2006 09:56 AM
