Shimming newer h22 lma's in older h22 head?
I am in the process of replacing my LMA's in my 94 h22 head with the spring type ones out of 98+ h22s.. and There is a visible height difference between the lifters, but the spring type feel stiffer. Do I still need to shim them? I bought some 5/16 washers that bring it up to a much closer height... I just wanna make sure before I put everything back together again
i dont see why you would need to shim them. The A1 and A4 heads are the same in that department, not really much different at all as a whole.
What kinda height difference are we talking here? The spring has a shorter installed height?
you should be able to use the washers. lots of B-series guys use the prelude LMA's with a washer to shim it up to the right clearence.
i do belive it has to be around .040 thou or .045 thou thick.
Well Mykizism said not to shim them, so I didnt.
I installed it and it runs fine, except the newer lma's seem noisier..
I noticed a thread with 2point6 saying the heads ARE different between the newer and old h22's.. which would mean I would have to shim them...
Maybe I'm being too critical, but are the spring type supposed to be alot noisier than the older ones?
Damit, I can't find it.........!
Well either way, I think these things make way too much noise.... I KNOW new preludes didnt make this much noise when they were new.. my rockers look fine.. Im just thinking I did have to shim them 0.040'' They were about 0.040'' shorter than the older ones too btw.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam_J »</TD></TR><TR><TD CLASS="quote">Damit, I can't find it.........!
Well either way, I think these things make way too much noise.... I KNOW new preludes didnt make this much noise when they were new.. my rockers look fine.. Im just thinking I did have to shim them 0.040'' They were about 0.040'' shorter than the older ones too btw.</TD></TR></TABLE>
u cant just adjust the valves?
thats where you are wrong. When doing a valve adjustment, you need to adjust them to .008 to intake and .006 on exhaust.
use .009 to check the intake
use .007 to check exhaust
i adjusted mine to those specs and check feeler should barely be able to be slid into the clearance and my valves have little to no chatter.
i used .008 on exhaust and 0.007 on intake PER THE HELMS.. Ill try and readjust them tomorrow, but I am positive the noise is the lifters not being tall enough....
Ok, Im in the process of readjusting the valves.. And I stumbled across something interesting...
If I put a piston on TDC, the middle lobe (vtec lobe) just flops around!! theres about a .040-0.045'' gap between the middle rocker and cam!!!!!
This is 100% hard evidence I have to shim these newer LMA's. There is no way that a gap like that can be good for the lma's or the rocker...
There are so many"experts" on the internet that speak with a lack of experience.
"Mykizism" is wrong. The pockets for the LMAs are different. Use a caliper and you will find that the 98+ heads are machined deeper.
To use the non encapsulated LMAs in a early head, you will need to use shims.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point6 »</TD></TR><TR><TD CLASS="quote">There are so many"experts" on the internet that speak with a lack of experience.
To use the non encapsulated LMAs in a early head, you will need to use shims.</TD></TR></TABLE>
thats nice to know
scott, are there any more differences like this between the a1 and a4 heads?
thats nice to know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point6 »</TD></TR><TR><TD CLASS="quote">correction.... 98+ head LMA holes are machined shallower. Sorry for the mistype.</TD></TR></TABLE>
I was gonna say..
That sounds more like it.
2point6, I'm normally on Hondasociety, and I've been following your N/A h22 threads for sometime now. I sent you an IM here on HT about this whole shimming newer lmas thing... I dont know if you got it or not.. Eitherway, I know you that have serious experience with these heads, and I wish you replied much earlier (having assembled my head without shimming them first) before I had to reassemble them with shims.. I'm glad to say after a overheating scare (funky rad cap) I am still running quietly and smoothly.
Thank you guys for helping me out.
B.Rabbit, I would like to meet up with some other h22 dudes in central FL sometime.. I want to get my p28 dyno tuned!
I was gonna say..
jdmcivicferio
24
Aug 23, 2007 08:13 AM
