Replaceing ABS modulator.
Mine is bad on my '92 teg, so I got another one off of ebay. Has anyone ever replaced one of these? I looks like there are seven metal lines connected to it and one rubber hose.
-Is there a process to replaceing this thing?
-Do I just disconnect all of the lines, remove the unit, put in the new one, then reconnect all of the lines?
-Also, do I have to bleed the ABS system some how?
-Is the ABS system isolated from the brake system fluid? In another words will I have to bleed my brakes also.
Any advic eon this job would be great.
Thanks
Thanks
Yes you will have to bleed the ABS system, and you will also have to bleed the brakes. I don't know about the actual procedure of replacing the modulator and bleeding the ABS, it's in the Helm's manual somewhere.
4doorH22
Sep 22, 2001 07:48 PM
