Being turbo + shifting gears.. what to do and don'ts .. ie Banging gears?
Old Dec 22, 2006 | 01:38 PM
JDM As It Gets's Avatar
Default Being turbo + shifting gears.. what to do and don'ts .. ie Banging gears?
i never officially learned the truths and myths on being turbo and racing it.. ie im hearing ppl say "dont bang gears when your turbo" (to let out all the gases and fumes so wastegate & blow off valve lets off all excess air?) also other misc stuff im hearing between driving it NA vs being Turbo.. IS THERE ANY REAL DIFFERENCe / GOOD OR BAD when beating on a NA car vs a Turbo Car..
Old Dec 22, 2006 | 01:48 PM
Bailhatch's Avatar
Default Re: Being turbo + shifting gears.. what to do and don'ts .. ie Banging gears? (JDM As It Gets)
If its built and tuned correctly you can drive it anyway you want to. The main difference driving a turbo honda is that, if you did it right, when you floor it in a corner the front end heads for the trees and you smell burning rubber.
Old Dec 22, 2006 | 01:58 PM
MotorMouth's Avatar
Default Re: Being turbo + shifting gears.. what to do and don'ts .. ie Banging gears? (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote"> if you did it right, when you floor it in a corner the front end heads for the trees and you smell burning rubber.</TD></TR></TABLE>
Sig material, some true words right there.
Old Dec 22, 2006 | 02:00 PM
Unsivil_audio's Avatar
^-lol.
The biggest problem I've seen is honda transmissions dont take to kindly to grabbing gears hard, splines like to shear off when your making 3-4x the power your car came stock with. (300+hp) But I guess that just comes with the territory.
Old Dec 22, 2006 | 02:11 PM
BoOsTiN Dc2's Avatar
Default Re: (Unsivil_audio)
i was banging gears left and right with no problem @ 300hp.... when your on street tires you cant full throttle it in 1 and 2 gear and sometimes 3rd because tires will break loose.
Old Dec 22, 2006 | 02:19 PM
Default Re: (BoOsTiN Dc2)
so banging gears is safe and wont break axles, damage trannies, ruin motor , break off piping cause of excessive force not escaping? this is for 300 and under wHP
Old Dec 22, 2006 | 02:24 PM
Bailhatch's Avatar
Default Re: (JDM As It Gets)
under 300 is gonna be pretty durable assuming the build is done right. my b16 turbo is all stock except for a clutch and sparkplugs and I beat the hell out of it every single day with no problems. It around 320whp. Generally it's the shock load of dumping the clutch that breaks driveline parts...there are people running 10s on stock trannys so i dont really worry about it.
Old Dec 22, 2006 | 07:18 PM
postman's Avatar
Default Re: (Bailhatch)
i see it as shifting quickly and banging gears are 2 totally different things which one do you do?
Old Dec 23, 2006 | 05:09 AM
DRAGLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM As It Gets &raquo;</TD></TR><TR><TD CLASS="quote">so banging gears is safe and wont break axles, damage trannies, ruin motor , break off piping cause of excessive force not escaping? this is for 300 and under wHP</TD></TR></TABLE>
I see it taking a toll on your synchros. Ever notice how alot of peoples 3rd gear grinds. The cause of that is the slamming of third gear 98% of the time.
Old Dec 23, 2006 | 07:19 AM
coneheadsracing's Avatar
lol, yeah right. You can break all that with stock hp, if you drive it the wrong way. You can shift fast, as long as your good, but its still excessive abuse. Spinning the tires, is a lot easier then your car hooking as far as driveline shock goes. You don't have to worry about gasses escaping though, thats what the blow off is for. Shift fast, but be smooth.
Also, if you did it right.... You should be able to start in second at 2000 rpm's, hit the gas, and by 3500 be spinning the tires, straight line
Old Dec 23, 2006 | 09:25 AM
Boner_Ben's Avatar
If you are making alot of power its easier on the trans to lift. Do it too slow and you'll fall out of boost.
Old Dec 23, 2006 | 09:34 AM
bart2546's Avatar
Default Re: (Boner_Ben)
Nice information here, I'll be taking it to heart for when my snail is attached.
Old Dec 23, 2006 | 10:14 AM
a1320addict's Avatar
Default Re: (bart2546)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">If its built and tuned correctly you can drive it anyway you want to. The main difference driving a turbo honda is that, if you did it right, when you floor it in a corner the front end heads for the trees and you smell burning rubber.</TD></TR></TABLE>
story of my life
Old Dec 23, 2006 | 11:40 AM
qfast817's Avatar
Default Re: (a1320addict)
dont mis-shift
pjr710
Jan 5, 2009 05:14 PM
TopFuel_RD
Nov 7, 2007 10:59 AM
ykracing
Mar 26, 2004 05:06 PM
r7
Oct 21, 2003 11:45 PM
youngwon22
Jun 1, 2003 08:58 PM
