Stock P8R or Ported PR4?
Old Dec 22, 2006 | 11:25 AM
AlienKrOZ's Avatar
Default Stock P8R or Ported PR4?
would a ported PR4 perform just as good a stock P8R head? im planning to do a head swap on my stock B18B. would be the same if i just send my current head out for a port abd polish job? i know at the end i might spend a lil more $ on this but i dont have to go around searching for a P8R head. would my ported PR4 head perform just as good as the P8R head or still have no comparsion to it?
Old Dec 22, 2006 | 06:52 PM
quicksilver1689's Avatar
i ♥ snails
p8r has different valve sizes i believe.
Old Dec 23, 2006 | 11:13 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
p8rs blow pr4s out of the water. the intake valves are 2mm larger (vtec head size), and the chambers are 84mm (not 81mm like pr4s). you can spend a ton of money to get these specs out of a pr4 (2mm larger valves is not easy to do), or you can just get a p8r and spend less money, and have more room for improvement with porting. make sure you use a 2.0l bottom end with it for best results. i plan on building up a p8r to the **** when i do a real build.
chad
Jul 7, 2011 09:27 PM
092eg6
Aug 7, 2009 04:50 AM
bigsnorlax
May 7, 2009 11:08 AM
egerdahl
Aug 15, 2005 08:47 PM
dunkd
Feb 27, 2005 09:12 AM
