headlight question
okay here's the question: my girlfriend bought me these hi intensity lights for my 94 del sol they're 100/120 watts. i wanted to check with HT to make sure that my system is able to provide enough power without destroying the sol's lighting system or taking too much power away from what's REALLY important (engine etc) thanks for the advice sorry if this has been covered used search but came up with nada...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mighty_sol »</TD></TR><TR><TD CLASS="quote">they're just the bulbs. they're nokyas or something like that</TD></TR></TABLE>
so just regular H4's? you should be good then..theres a lot of people on here that run those bulbs
The higher wattage bulbs will likely draw too much current for your stock wiring/connectors to handle, and they will also generate an excessive amount of heat that could potentially melt the plastic oh your housings.
inspireAZN
Lighting
17
Jan 14, 2008 09:54 AM
