Idle Problems...
Old Dec 22, 2006 | 08:53 AM
Mr Synister's Avatar
Default Idle Problems...
Ok I have a B16 swap and when I start it up it idles at 2000k but goes down as it gets warm to a lil below 1000k. It idles fine until I run it for awhile then when I stop it idles above 1000k to 1500k. Why is that ?
Old Dec 22, 2006 | 08:56 AM
nappyroots827's Avatar
Default Re: Idle Problems... (Mr Synister)
could be a stickin thottle cable or dirt on the plate...next time it happens put ure foot under the gas pedal and pull out on it and see if it drops
Old Dec 22, 2006 | 08:57 AM
Default Re: Idle Problems... (nappyroots827)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nappyroots827 &raquo;</TD></TR><TR><TD CLASS="quote">could be a stickin thottle cable or dirt on the plate...next time it happens put ure foot under the gas pedal and pull out on it and see if it drops</TD></TR></TABLE>
I've actually tried that and no dice. Any other suggestions ?
Old Dec 22, 2006 | 09:37 AM
C_R_X_V_T_E_C's Avatar
IAVC or the FCCV
Old Dec 22, 2006 | 10:17 AM
RockinthEFhatch's Avatar
Default Re: Idle Problems... (C_R_X_V_T_E_C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_R_X_V_T_E_C &raquo;</TD></TR><TR><TD CLASS="quote">IAVC or the FCCV</TD></TR></TABLE>
Just get an aftermarket throttlebody
Old Dec 22, 2006 | 11:41 AM
schueytenten's Avatar
Thinking, thinking, thinking. What is the FCCV? Google brings me to The Feline Control Council of Victoria. Pretty sure that is not it, but with the way my car has been idling, I might try throwin a cat or two in there.
Old Dec 22, 2006 | 12:05 PM
Default Re: Idle Problems... (schueytenten)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schueytenten &raquo;</TD></TR><TR><TD CLASS="quote">Thinking, thinking, thinking. What is the FCCV? Google brings me to The Feline Control Council of Victoria. Pretty sure that is not it, but with the way my car has been idling, I might try throwin a cat or two in there. </TD></TR></TABLE>
He really meant IACV (Idle air control valve) and FITV (Fast Idle Temperature Valve) This is my old throttle body which I replaced with a Spoon TB
Old Dec 22, 2006 | 02:33 PM
Default Re: Idle Problems... (RockinthEFhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockinthEFhatch &raquo;</TD></TR><TR><TD CLASS="quote">
May I ask what the spoon throttle body set you back?
Old Dec 22, 2006 | 03:17 PM
Honestly it was listed on eBay in the worst place, so if people were looking for it they couldn't find it. It was like boat motors or something. Regardless it only cost me $150. I've gotten some sweet deals on eBay my friend. I highly recommend checking it once a week for rare parts.
Old Dec 22, 2006 | 06:00 PM
Brick Top's Avatar
try this
https://honda-tech.com/zerothread?id=1564019
if not, try cleaning your IACV or coolant might have bubbles in it.
Old Dec 22, 2006 | 10:17 PM
Default Re: Idle Problems... (brick top)
let your car get up to operating temperature and unplug the IACV and if the idle drops then you have a problem with the IACV if it stays, then its something else
Old Dec 23, 2006 | 11:43 AM
mat18's Avatar
some good info!
Old Dec 23, 2006 | 12:03 PM
91ed9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brick top &raquo;</TD></TR><TR><TD CLASS="quote">try this
try this
if not, try cleaning your IACV or coolant might have bubbles in it.</TD></TR></TABLE>
this works i did it to mine this morning b16a , and no more high idle , and i aso had a surge problem idling from 2600 to 900 on cold start and i cleaned it out readjusted and my car idles beautiful
Old Jan 4, 2007 | 07:23 PM
gsxr1k05's Avatar
Default Re: Idle Problems... (1991 CRX Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1991 CRX Si &raquo;</TD></TR><TR><TD CLASS="quote">
this works i did it to mine this morning b16a , and no more high idle , and i aso had a surge problem idling from 2600 to 900 on cold start and i cleaned it out readjusted and my car idles beautiful </TD></TR></TABLE>
another honda b16 swap that this fixed the high ide problem for.. i was idleing at 2k and it started yesterday to surge every now and then.. stuck my finger on the hole and high idle goes from 2k cold to 1100.. WOOT!!!! i taped it up.. i will clean it someday.., probably not.. just gonne get an aftermarket intake and tb later on.. hope nothing bad comes from taping it up.. i used clear packing tape.
Old Jan 5, 2007 | 08:43 PM
tapboyzlilj's Avatar
Alright drive your car around until it gets warm, leave your engine on with the idle going up an down, use a plyer an clamp on the PCV valve hose from your IM if it stops PCV is bad or AIR leak somewhere...
eg_civic209
Dec 1, 2006 06:11 AM
vc
Aug 22, 2006 02:19 PM
civic_eh
Dec 30, 2005 05:18 PM
Btothe3rdDegree
Oct 30, 2004 10:33 PM
hondasport2000
11
May 11, 2004 12:27 PM
