tires have camber??
Old Dec 22, 2006 | 01:25 AM
Nicks95GSR's Avatar
Default tires have camber??
Hey guys well I was wondering what CAMBER means. Cuz I was looking at these Blades, but the guy says that the tires have CAMBER. So if you guys could help me out that would be koo. Thanx
Old Dec 22, 2006 | 01:55 AM
Fat Chick Magnet's Avatar
if the car is lowered the tires tuck in and they wear out uneven.
camber is good for handlingggggggg!
Old Dec 22, 2006 | 05:42 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
What the guy meant was that they have camber wear. Camber is not an object, it's a description of the angle of the tire relative to the ground.
But in reality, the wear on the tires are most likely from incorrect toe in combination with negative camber. Go to tirerack.com, it will explain all things related to tires and alignment, etc.
Old Dec 22, 2006 | 07:44 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Go to tirerack.com, it will explain all things related to tires and alignment, etc.</TD></TR></TABLE>
http://www.tirerack.com/tires/...hid=4
Old Dec 22, 2006 | 07:56 AM
.brian.'s Avatar
Default Re: (nsxtasy)
think of it this way....if you are standing in front of the car looking head on at it, normally, this is how your tires would look:
l l
this is how they look if you have camber:
or:
if the tires are sitting like that, do you see how that would produce uneven wear on them?
DJNauTicz
Oct 9, 2007 03:27 PM
jnuanz382
May 4, 2007 10:11 PM
VtecFreePrelude
Sep 29, 2006 08:21 AM
vsm dc4
Jan 31, 2005 11:01 AM
todds94teg
Sep 5, 2003 06:14 AM
