camber kit?
will 92'-95' Civic adjustable upper arms fit my 91 STD Hb? my trailing arms and rear lower control arms are EG6 so i figure if the back suspension fits why not the front?
if you need more than +3 ged you are gonna be looking at issues clearing the inner fender wall. i just installed my ghetto ebay camber today (adjusts the upper control arm). i went plus 2.4 on one side, and 1.7 on the other, and the 2.4 was a bit of a bitch. had to pry bar the inner fender wall quite a bit. if you are adjusting more than +3 you are gonna need to bust out the dremel on the wheel well and your nice new shiny control arms. good luck gettin those wheels straight.
Dan
Dan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickeynick »</TD></TR><TR><TD CLASS="quote">will 92'-95' Civic adjustable upper arms fit my 91 STD Hb?</TD></TR></TABLE>
No.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">my trailing arms and rear lower control arms are EG6 so i figure if the back suspension fits why not the front?
Because that particular part happens to be different, unfortunately.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHUTTLE »</TD></TR><TR><TD CLASS="quote">they only have +3 -3 neg camber its not enuff for a adjustment it will still have camber issues</TD></TR></TABLE>
If +3.0* of adjustment won't get your lowered car back into the factory spec tolerance range, you're doing something wrong.
If you're trying to set front camber to 0.0*, you're also doing something wrong.
No.
</TD></TR></TABLE>Because that particular part happens to be different, unfortunately.
idreamHonda
Suspension & Brakes
Apr 16, 2005 01:44 PM
down_the_hatch
10
Feb 17, 2005 06:40 AM
