disappearing oil
Old Dec 21, 2006 | 08:18 PM
smeck's Avatar
Default disappearing oil
some time ago I found out my car ('97 5th gen prelude, 2.0i) was completely drained of oil (Just bought it a month before and there was plenty of oil when I had it checked before buying).
So I filled it up again, and was very relieved that I found out just in time. And losing about 5 litres of oil in a month isn't a good thing, I assumed it was leaking somewhere, although there was no leakage found at the pre-buy check.
But after leaving it standing on a clean concrete floor at work for about 13 hours, but there wasn't a single drop of oil to be found, which pretty much ruled out leakage.
So the other explanation would be that it was using the oil (crooked pistons or someting), but that would mean I would get black or colored exhaust fumes...which is also not the case.
So my question is: what could be a explanation for the fact that my engine uses about 1 litre of oil every 600/700 km?
Old Dec 22, 2006 | 08:21 AM
thesmogman's Avatar
Default Re: disappearing oil (smeck)
Could be a few things.
A stuck open PCV valve can do it.
Blowby... rings/seals
Try a new PCV and see. I lost a 1/2 a quart in 50 miles.
Old Dec 22, 2006 | 09:14 AM
smeck's Avatar
Default Re: disappearing oil (thesmogman)
thnx for the tip, giving it a try first thing next week
Old Dec 27, 2006 | 03:23 PM
smeck's Avatar
well I checked it, and had it checked but there was nothing wrong with the pcv.
any other suggestions?
Old Dec 28, 2006 | 08:10 AM
thesmogman's Avatar
I don't think you can check it completely. I would replace it. I pulled mine out and cleaned it. It looked good and the valve was moving, but it was still bad.
If it is not dripping then it is getting burned. Rings, or valve seals is my next guess.
Old Dec 28, 2006 | 11:43 AM
LSVTEC 91 Civic's Avatar
Banned
Do a compression/leakdown test.
For a band-aid fix, try using some thicker oil to slow the consumption down.
Old Dec 28, 2006 | 07:35 PM
JOE BD-0's Avatar
[QUOTE=smeck]
Burning oil makes BLUE smoke.......BLACK smoke is from too much fuel....good luck
Old Dec 28, 2006 | 11:38 PM
GetawayInMoscow's Avatar
Default Re: disappearing oil (JOE BD-0)
im going to guess piston rings...
Old Dec 31, 2006 | 04:38 AM
smeck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOE BD-0 &raquo;</TD></TR><TR><TD CLASS="quote">
Burning oil makes BLUE smoke.......BLACK smoke is from too much fuel....good luck</TD></TR></TABLE>
I know that's why i said colored smoke
and thanks for the suggestions! I'm having it fully checked next week and replace all the possible broken parts, because I want to sell it to partialy finance my h22a type-s swap
Old Dec 31, 2006 | 11:57 AM
Scott_Tucker's Avatar
Default Re: (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Do a compression/leakdown test.
For a band-aid fix, try using some thicker oil to slow the consumption down.</TD></TR></TABLE>
A compression and leakdown test will not tell you anything about your oil control rings.
calvinkw1
Nov 18, 2005 06:49 AM
redlineSH
Jul 27, 2004 07:32 PM
CroSi
Aug 14, 2003 04:32 PM
Pinpid
Dec 17, 2002 04:55 PM
