rear disc question. *searched*
i just bought EG rear disc...i have a 1991 STD Hb. I need to know what e-brake cables? and what brake fluid lines i need? and do i need a different master cylinder? i have the cables and lines that came with the disc. i don't know if they'll work and don't want to take the car apart unless it will fit.
you need integra lines for the backs and the integra e- brake cables.
I dont know if the Eg ones will work on the EF though. should have gottem them from a 90-93 teg
good luck
good luck
sweet! master cyl isnt necessary but it helps to get a bigger one along with the prop vavle.
I upgrade my stock MS and Brake boster to a 91 Ex 4 door and it feels awsome!
teg brakes all around and its such an improvement over the stock brake system.
I bought eg rear brakes from HMO. I used the brake lines and cables that came with the setup. The only thing I changed was the bracket that bolts the assembly to the chassis. I swapped it out for my 91 dx's. It's the bracket at the far end of the assembly. I had already swapped my MS and BB to a 91 ex before the swap. The cable lines are tight, but doable. Been driving it like that for over a year.
kyle2436
Feb 23, 2009 05:56 PM
