'94 Keeps Shutting Off While Driving
Old Dec 21, 2006 | 07:49 PM
hondagrl4261's Avatar
Default '94 Keeps Shutting Off While Driving
My '94 (automatic tranny) has cut off on me three times in the last week while driving (twice on the Interstate) It hasn't been making noise that I notice or anything, but the "check engine" light comes on and the car stops. I have always manged to steer it to the shoulder. I have to shut it off for a couple of minutes, but then it starts right back up. Last night it shut down. I started it back up and while running, the battery and oil lights came on. The only common thread is that this seems to happen when the car isn't warmed up enough. Does anyone have any thoughts or insight on this?
Old Dec 21, 2006 | 07:53 PM
TheMuffinMan's Avatar
He knows where you live!
First thing to do would probably be to try to find out what the code is the CEL is showing.
When was the last time it was in for a tune up?
I would suggest stopping by an Advanced or someplace along those lines, have them check your battery/alternator and pull the CEL
Old Dec 21, 2006 | 07:56 PM
HondaTech101's Avatar
Default Re: (TheMuffinMan)
happened to my friend and his truck not to long ago. turned out an alternator wire was lose. ide check them all. if not idk what to tell ya.
Old Dec 21, 2006 | 08:09 PM
oodie's Avatar
Default Re: '94 Keeps Shutting Off While Driving (hondagrl4261)
Take it and get the check engine light looked at but it sounds like somthing small.
Old Dec 21, 2006 | 08:10 PM
hondadude's Avatar
Check for codes
Sounds like possible Ignition switch, I doubt it's a truck with a loose Alt wire.
sony224422's Avatar
Default Re: (HondaTech101)
check to make sure the alternator is working properly. Usually when the dummie lights go off at the same time, its your alternator not working properly. Autozone and places will test it for you if you need. Make sure the terminals are tight on your battery too.
Old Dec 26, 2006 | 08:27 PM
Default Re: 94 Honda Shutting Off
Thanks!
I am taking it to the shop today...
Old Dec 26, 2006 | 09:10 PM
YeuEmMaiMai's Avatar
check cel and tell us. it could be the ignition module
Old Dec 26, 2006 | 09:57 PM
D16Z6racing's Avatar
Default Re: (YeuEmMaiMai)
happened to me a couple of times. i had to replace my distributor.
Old Dec 27, 2006 | 02:29 AM
Default Re: (D16Z6racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16Z6racing &raquo;</TD></TR><TR><TD CLASS="quote">happened to me a couple of times. i had to replace my distributor.</TD></TR></TABLE>
happened to me when I first got my '94 accord checked and tightened all grounds and 80K later problem had not returned.
Old Dec 28, 2006 | 05:08 PM
Default Re: '94 Honda Keeps Shutting Off While Driving
The verdict is in ---
Problem: Main Relay. The engine was not getting enough gas, hence the shutting down problems. Tech was surprised this happened during the fall/winter because this typically occurs during the summer months, with over heating,etc. VERY inexpensive to fix. Needless to say, I am an extremly happy Honda girl once again.
Tayla Mayde
Jun 6, 2013 05:08 PM
Heat
Dec 2, 2007 06:55 PM
lordcarlo
10
Oct 4, 2007 10:26 AM
S2KILLA
Jul 28, 2005 08:26 AM
97VtecIN
Nov 6, 2004 05:14 AM
