IAT IACV PROBLEM....searched for hours on end and still nothing...
Old Dec 21, 2006 | 03:48 PM
slowpokecivic's Avatar
Default IAT IACV PROBLEM....searched for hours on end and still nothing...
ive been reading about the iat and iacv and gained some knowledge...
thing is, my car is still throwing a code for the iat even tho its just been replaced with a brand new unit...
i am in the process of cleaning the iacv with brake cleaner but how come im still throwing a code if the iat has just been replaced?
running a chrome chipped p28 on a jdm itr motor...
and also, i dont have a cold start idle anymore, it just idles at 700-800 as if the motor was already at op temp...wats that all about...?
Modified by SLoWpOkECiViC at 4:58 PM 12/21/2006
Old Dec 21, 2006 | 04:49 PM
schardbody's Avatar
sounds like the program on your chip. who setup the program you are running???
Old Dec 21, 2006 | 04:59 PM
Kafelatte's Avatar
Default Re: IAT IACV PROBLEM....searched for hours on end and still nothing... (SLoWpOkECiViC)
try reseting the ecu. my friend had the same problem with his iat. we reset the ecu and the code went away.
Old Dec 21, 2006 | 05:30 PM
Default Re: IAT IACV PROBLEM....searched for hours on end and still nothing... (kay20adc2)
mtber set it up...
it was running fine just a few days ago...i messed up when i switch the harness from the iacv to the iat...it melted the iat, so i replaced it...i never plugged it into the iacv tho...
ive tried resetting the ecu like fifty times already...and it still pops up...no matter what i do...
anymore ideas?
mc's Avatar
mc
:edit:
Modified by mc at 6:43 AM 12/22/2006
Old Dec 21, 2006 | 05:58 PM
schardbody's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLoWpOkECiViC &raquo;</TD></TR><TR><TD CLASS="quote">mtber set it up...
anymore ideas? </TD></TR></TABLE>
haha, thats what happened, your ECU is now fried buddy. search, this problem happens ALOT, well, more than it should, instantly fries the computer, or part of it, and unless you can solder you might as well get a new ecu.
Old Dec 21, 2006 | 06:13 PM
Default Re: IAT IACV PROBLEM....searched for hours on end and still nothing... (schardbody)
so your saying if i plugged this ecu into another car...the same codes are going to pop up?
Old Dec 21, 2006 | 06:30 PM
schardbody's Avatar
yep, most likely, plugging the iacv connector into the iat will melt one of the capacitors in the ECU almost instantly, im surprised you didnt see the smoke out the ecu, pull the cover and inspect the internals on the ecu and you will see.
Old Dec 22, 2006 | 01:47 AM
Default Re: (schardbody)
will do...nother question, is the ecu fixable? if say i repaired said capacitor? also, i took my car out for a test drive, and everything seems to be working just fine...
vtec engages at 5600, no rev limiter well at least upto 8k...motor seems to run okay except for maybe the rough idle...
o thanks schardbody for all the help...really appreciate it...
this is what honda-tech needs to be like...
Old Dec 22, 2006 | 01:48 AM
also, someone mentioned about adjusting the tps...how do i go about doing so?
Old Dec 22, 2006 | 06:40 AM
schardbody's Avatar
your ecu should be fixable, just the iacv curcuit is blown in the ecu now, as for adjusting the TPS, it probably wont help you any but you can do so, just look for it in the FAQ sticky, or search, its been covered.
sevenfc
45
Oct 15, 2009 03:52 AM
DarkBB4
May 8, 2008 06:04 PM
StolenTeg
Jan 6, 2008 03:09 PM
dad0c402
May 5, 2007 08:06 PM
