OK....Issues when turning left.
Old Dec 21, 2006 | 03:02 PM
Bejita's Avatar
Default OK....Issues when turning left.
Ok here we go...I've searched the **** out of this and I'm leaning towards axle issue more and more. BUT!! I would like some opinions.
My setup is a 1990 Hatch with a B16A swapped into it. I have a J1 tranny which means my axles are 90-91 integra axles. This car has run fine up until recently. Only when I turn left I hear this whining noise. Not a clunk or a click like normal CV/axle issues. It's like a wher wher wher wher noise and it doesnt do it when I let off of the throttle. As soon as I let go and start rolling it stops. As soon as I touch the throttle it starts again...What the hell could this be?
One more smaller issue. I have a rear disc conversion and when I'm rolling to a stop or just driving I hear this noise in the back kinda like a clunk clunk clunk that follows my speed range. Any ideas on that?
I've checked all of the obvious stuff like rubbing and bad tires but havent found anything.
Old Dec 21, 2006 | 03:03 PM
cb07's Avatar
When you did the rear disk conversion, did you do anything to the brakes? Like rebuild calipers, new pads, etc... Just wondering because when I had that same clunking noicse while stopping, it turned out I needed pads really really bad.
Old Dec 21, 2006 | 03:07 PM
Bejita's Avatar
When I got the car the conversion was already done. Everything looks new and works really well. I'm starting to wonder if the wheels need to be rebalanced.
Old Dec 21, 2006 | 06:23 PM
mahatma's Avatar
Default Re: OK....Issues when turning left. (Bejita)
i wouldn't rule out a wheel bearing for either of those issues.....although i think you're right about axle in the front. does you steering wheel shake?
might be worth your while to take one side apart and check to see that the dust rings were removed from your spindles. i don't think you can see them (or not) with the axles in there.
Old Dec 21, 2006 | 09:17 PM
Bejita's Avatar
No..The steering wheel doesnt shake...I'm gonna replace the bearings and if that doesnt work.....axle swap.
Old Dec 21, 2006 | 11:14 PM
abnaasefmb's Avatar
Default Re: (Bejita)
tire rub?
Old Dec 22, 2006 | 03:49 AM
Bejita's Avatar
Default Re: (abnaasefmb)
No tire rub........
Old Dec 22, 2006 | 05:03 AM
JustAnotherRex's Avatar
Default Re: OK....Issues when turning left. (mahatma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">i wouldn't rule out a wheel bearing for either of those issues.....although i think you're right about axle in the front. does you steering wheel shake?
Steering wheel shake = bad axles? ****, I've got something else to add to my list. I was just thinking I needed to check my ball joints.
Old Dec 22, 2006 | 12:32 PM
abnaasefmb's Avatar
Default Re: OK....Issues when turning left. (JustAnotherRex)
check you tranny fluid level
Old Dec 22, 2006 | 05:28 PM
Bejita's Avatar
Thats a really good idea....I'll do that.
Old Jan 1, 2007 | 04:46 PM
Bejita's Avatar
PROBLEM SOLVED!!! It was the bearings!! Replaced em both.
Old Jan 1, 2007 | 05:14 PM
abnaasefmb's Avatar
Good to hear. It’s also good to follow up, one more problem in the archives.
ra64
Mar 8, 2015 09:45 AM
uses0ap
Oct 25, 2008 09:02 AM
WhitEdRift
Mar 11, 2004 08:48 PM
cbmlsvteg
Oct 17, 2003 06:15 PM
Steveo92'vx
Sep 1, 2003 09:38 PM
