ek with gsr swap wiring problems
Old Dec 21, 2006 | 02:59 PM
sillyme77's Avatar
Default ek with gsr swap wiring problems
i'm using the stock sohc vtec harness from the ex. but notice that the crank position sensor has a different plug. 3 prongs instead of the 2 that is on the gsr. do i need to wire that up? how do i do it? what do i do about the alternator plug also? can i just swap out alternators? thanks
Old Dec 21, 2006 | 03:26 PM
Sloshy's Avatar
what year is you gsr swap?
Old Dec 21, 2006 | 03:35 PM
sillyme77's Avatar
Default Re: (hatch-E-vanish)
96 gsr motor
Modified by sillyme77 at 5:37 PM 12/21/2006
Modified by sillyme77 at 5:38 PM 12/21/2006
Old Dec 21, 2006 | 03:49 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (sillyme77)
The 95 GSR won't have the crank position sensor on the oil pump like OBD2 models. If you plan on using an OBD2 ECU you will either have to get an OBD2 GSR oil pump or do this trick : http://www.ff-squad.com/technet/ckftrick.htm For the alternator:
Old Dec 21, 2006 | 04:41 PM
sillyme77's Avatar
Default Re: (HondaPartsHero)
sorry it's a 96 motor has a 2 prong crank sensor by the belts.
Old Dec 21, 2006 | 04:54 PM
Kafelatte's Avatar
Default Re: ek with gsr swap wiring problems (sillyme77)
try to find a 2 prong plug. cut and resolder it to the ex harness and just color match the two to the gsr and disregard the 3rd wire.
Type_EK_R
Nov 3, 2023 05:23 AM
nick21
Jun 29, 2016 07:12 AM
enot767
14
Jan 5, 2011 07:27 PM
dc4teggiehatch
Dec 2, 2007 03:00 PM
dc4teggiehatch
Nov 25, 2007 05:54 PM
