My car won't start!
Old Dec 21, 2006 | 12:51 PM
SergeS2K's Avatar
Default My car won't start!
Ok as some of you may know I made the other thread about replacing my head gasket, well I made a new thread now because not everyone looks at the last reply but this is my latest problem. Today I finally got everything set up and put together. I go to start my car......and it won't start! It trys too but that's as far as it goes. I don't know what the problem is.....is it a timing problem? I had everything set in the right place.....but since it's my first time doing this I guess maybe I fucked up somewhere else? I couldn't find anything out of it's place or any hoses or anything, I'm sure everything is conncected....I'd really like to drive my car again so please help lol.
Old Dec 21, 2006 | 01:06 PM
Nors's Avatar
Check fuel. Check spark. Check compression.
Old Dec 21, 2006 | 01:09 PM
SergeS2K's Avatar
Ok here goes a dumbass question lol. How do I check for fuel or spark? And I don't have a compression tester.
Old Dec 21, 2006 | 01:15 PM
Blk-dc2's Avatar
Default Re: (SergeS2K)
sounds like your timing might be off.....
Old Dec 21, 2006 | 01:18 PM
SergeS2K's Avatar
How would I fix the timing? I could of sworn I had it right, I was following the haynes manual. I had the first cyclinder at TDC when replacing the head gasket. When I got the Camshafts back on I had both of their UP marks facing up and when I got the distributor on I had the roter pointing to the 1st sparkplug wire. Maybe I screwed something up? Or is it supposed to be something different?
Old Dec 21, 2006 | 02:01 PM
Blk-dc2's Avatar
i know some times when you put the belt back on it moves the timing off so try that first...then i would move from there...
Old Dec 22, 2006 | 02:13 PM
DB1_559's Avatar
Default Re: My car won't start! (SergeS2K)
need more info is it a ls/gsr etc i can be valve lash/timing
Happiest92Ricer
12
Jun 28, 2013 08:52 AM
scotty.b16a1
Jan 2, 2013 04:54 AM
jonnybadboi9
Jul 15, 2009 09:39 PM
rodvang
Dec 25, 2007 08:37 AM
Red93AWD
10
Aug 16, 2005 06:45 PM
