Fuel Pump randomly shutting off?
Old Dec 21, 2006 | 10:53 AM
94delsol6428's Avatar
Default Fuel Pump randomly shutting off?
My fuel pump randomly shuts off, sometimes at idle, sometimes when I'm driving it. Usually if I wait for a little while, or get it towed, it will start up again. I've had it towed 4 times in the past 2 and a half weeks, and every time it gets off the truck it starts up great! I can hear a clicking sound coming from near the fuse box inside. The clicks correspond with the fuel pump turning on and off, it clicks and goes on and off quickly for a full second or so and then completely shuts off. I was told it could me the fuel pump relay, but I can't find a specific 'fuel pump relay' and was told that any of the relays could be related to the fuel pump. I replaced the main relay and it didn't fix the problem. Could it be a short in the fuel pump wiring or something? Is there a way to completely bypass all the relays or current wiring and just install a hidden on/off switch for my fuel pump? Could the temperature outside have anything to do with it?
Old Dec 21, 2006 | 12:13 PM
92civichatch1's Avatar
Default Re: Fuel Pump randomly shutting off? (94delsol6428)
check the main relay its usually the culprit
Old Dec 21, 2006 | 08:46 PM
Default Re: Fuel Pump randomly shutting off? (92civichatch1)
I'm already replaced the main relay, and it still does the same thing. I had it in to a Honda dealership and it never stalled out on them, they had it for a week and a couple days. Not sure why I'm the only one it stalls out on, I baby the car. This is it's 2nd winter on the roads, not sure if it likes it.
Old Dec 21, 2006 | 08:49 PM
sasser43's Avatar
The fuel pump in my trans am would go out and come back on just like that. Then it went completely out, so it could just be a sign of the fuel pump going bad.
Old Dec 21, 2006 | 10:03 PM
sal's Avatar
sal
Default Re: Fuel Pump randomly shutting off? (sasser43)
Check the ground to the left of the drivers side seat, under the carpet. My car was just having a similar problem and that ground had a bad connection. As soon as i tightened it up my pump turned on right away and hasn't given me any problems since. BTW, my car is a 94 hatch. Not sure if del sol's are setup the same.
Old Dec 22, 2006 | 12:03 AM
Default Re: Fuel Pump randomly shutting off? (sal)
The first thing I thought of was the fuel pump, but I got a Walbro. Myself and all my friends thought it was crazy that a Walbro went bad, but I swapped it out with a friends Walbro and the same thing happened. I'll check the ground tomorrow, my car is stuck at work right now.
Old Dec 22, 2006 | 12:53 AM
tietze's Avatar
Like SAL said, check that ground going to the main relay. (black wire)
Disconnect the connecter to the main relay.
Use a ohmmeter to verify continuity from body ground to the black wire.(pin 2)
You should have 12v at pin 1, (yel/wht), all the time.
You should have 12v at pin 5,(blk/yel), when the ignition switch is on.
Try your friends ECU.
Intermittent problems are the worst.
Old Dec 27, 2006 | 07:06 PM
92BLKsihatch's Avatar
Default Re: Fuel Pump randomly shutting off? (tietze)
I am having the same problem... is your main relay for sale? LOL
Modified by 92BLKsihatch at 5:47 PM 12/29/2006
hatchBK4life
Aug 2, 2010 05:11 PM
ksbenjamin44
Jun 25, 2009 05:22 PM
zippakilla
Feb 6, 2009 04:01 AM
datonefoo1
Feb 8, 2008 12:29 PM
