gauge cluster problems....
95 civic coupe with a gsr engine, previous owner swapped a gsr cluster on the car. I'm trying to put a civic cluster back but i'm having problems with the wiring. the wires don't match up at all, none of the color matches from the old wiring harness to the plugs that came with the civic cluster. can someone post up a diagram??? thanks in advance.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_hb_enthusiast »</TD></TR><TR><TD CLASS="quote">95 civic coupe with a gsr engine, previous owner swapped a gsr cluster on the car. I'm trying to put a civic cluster back but i'm having problems with the wiring. the wires don't match up at all, none of the color matches from the old wiring harness to the plugs that came with the civic cluster. can someone post up a diagram??? thanks in advance.....</TD></TR></TABLE>
you have to change the pins back to the right place. get a eg diy, and a dc diy,
make such that you get the right diy, for the dc....
here is a link to help. http://www.jdmlyfestyle.com/
turbotime
May 4, 2006 09:49 AM
importboi22
May 31, 2004 10:32 PM
