98 coupe Swap
Old Dec 21, 2006 | 10:02 AM
tangou's Avatar
Default 98 coupe Swap
hi
i have 98 2.3 coupe. i would like to swap to something better. which engine You could offer me to do that. witch which i could have least (less) problems, and what parts i might need for swap. i tried browse the treads, but didnt find anything.
thanks a lot
Old Dec 21, 2006 | 10:11 AM
HandoEX's Avatar
Default Re: 98 coupe Swap (tangou)
Seriously, there are a billion theads on this. Use the Search button on the top right side of your screen
Old Dec 21, 2006 | 10:25 AM
philadd's Avatar
Default Re: 98 coupe Swap (HandoEX)
Or, if you don't know what to type in (or just too lazy to)... try going through the Accord FAQ.
Old Dec 21, 2006 | 10:38 AM
tangou's Avatar
i know, but there some technicl facts that im not so good in. i tought that You could just tell me whitch swap possibility is less complicated. anyway thanks...
Old Dec 21, 2006 | 12:13 PM
YeuEmMaiMai's Avatar
Default Re: (tangou)
possible swaps from least to most expensive
1. frankenstien motor (IE H2x heads F2X block)
2. Turbo
3. H22a
4. V6
5. CL type S engine swap
Old Dec 30, 2006 | 06:45 AM
tangou's Avatar
got an obx header. heres the questiona about a sensor. where it goes? . because on obx header there's no hole for it ? what to do with the sensor?
thanx as always.
Old Dec 30, 2006 | 11:44 AM
philadd's Avatar
The hole is further downstream. You'll need to extend the O2 sensor wires to reach.
Old Dec 31, 2006 | 07:38 AM
nViDia-ForCeZ's Avatar
Default Re: (philadd)
uh oh.. sound like you are going to be in sooo much trouble... i dont think you should do a swap yet and start doing some homework till you get all the information you need. that what i would do first...
Old Dec 31, 2006 | 07:44 AM
Prodigal Son's Avatar
Default Re: (nViDia-ForCeZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nViDia-ForCeZ &raquo;</TD></TR><TR><TD CLASS="quote">uh oh.. sound like you are going to be in sooo much trouble... i dont think you should do a swap yet and start doing some homework till you get all the information you need. that what i would do first...</TD></TR></TABLE>
Agreed. If you want to do the work yourself, start with bolt ons and learn more about your car. Otherwise if money isn't the big issue, enlist a shop to help you. Don't mess up a working car trying to 'fix' it if you don't know how. We all started somewhere
Old Jan 1, 2007 | 08:14 PM
Patman's Avatar
I'll come pay for in cash and remove your 2.3 for 300 bucks, how many miles on it?
Old Jan 1, 2007 | 09:03 PM
street_accord94's Avatar
Default Re: (Patman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patman &raquo;</TD></TR><TR><TD CLASS="quote">I'll come pay for in cash and remove your 2.3 for 300 bucks, how many miles on it?</TD></TR></TABLE>
so youre going to go all the way to the UK for his motor huh?
Old Jan 1, 2007 | 10:26 PM
Patman's Avatar
yep
Old Jan 1, 2007 | 10:57 PM
tangou's Avatar
like You guys said - we should start some day. so i'm tryin. i will not do nothing untill i know ewerything for sure. thats why i'm here - to ask someone who knows. thank you for info indeed.
Old Jan 2, 2007 | 07:41 AM
CCP's Avatar
CCP
Search is your friend
Old Jan 20, 2007 | 07:12 AM
tangou's Avatar
i have problem.
today i swaped my old manifold and cat to obx manifld and cat converter. but after i took car from garage i saw that rpm's dropping till 200, when i accelerate car is shaking. when im reaching 3000 rpm's everythings becoming ok. at home i noticed that service man puted o2 sensor n1 into sensors n2 (which was in cat and nov in converter) place. maybe if i replace them (will put where the should be) ewerything will be ok ?, or maybe now when i dont hawe cat i dont need sensor out there ?. help me im so confused...
Old Jan 20, 2007 | 10:11 AM
tangou's Avatar
i checked some treads and info on internet. is it possible that on swaping headers the sensor could be broken? now repair-man swaped sensors. i mean he puted front sensor in to rear sensor place and rear into front's. all i need is to swap them back. and if nothing changes - buy new sensors ? . is that right solution ?
Old Jan 20, 2007 | 06:41 PM
aznpridelivin2o3_cg5's Avatar
H22A yO !
Old Jan 21, 2007 | 04:46 AM
tangou's Avatar
today i puted a o2 sensors in th eright places, but i still have the problem. when i',m accelerating on warm engine the car is shaking and trembling till its reaching 3000 rpm's. when im relieasing gas [edal rpm's dropping till 200 for a few seconds and coming back to normal position. i have no ideas but the sensor.
1sikhatch
Oct 20, 2005 01:13 PM
deviltodomestics
Oct 19, 2004 01:19 PM
lippage2004
Mar 17, 2004 04:17 PM
