mini me help
Old Dec 21, 2006 | 08:33 AM
204E-EF6's Avatar
Default mini me help
i have a d16y7 and i want to swap the head for a 92 sohc vtec head to make a mini me,right now i have my stock d15 intake manifold on my d16y7 right now,what do i need to make this happen,parts needed and info or maybe pics,or diagrams would help
Old Dec 21, 2006 | 09:15 AM
e jay one's Avatar
Default Re: mini me help (E-EF6)
you have dpfi? you need an intake mani for mpfi convert your car to mpfi then convert it to obd1. search mini me for a write up.
Old Dec 21, 2006 | 12:10 PM
204E-EF6's Avatar
right now im running dual,what excactly do i need to convert to multiport,would it be better to use my d15 harness and just add the wires that are needed or would it be better to use a si harness,im pretty much clueless right now
Old Dec 21, 2006 | 01:14 PM
guy_from_nerk's Avatar
Default Re: (E-EF6)
well since your putting a vtec head on, you might as well convert to obd1 while your at it and run the p28 ecu found in the 92-95 civic si and ex. If you choose to stay obd0 and run a vtec controller you will need the following:
Injector Resistor box
Intake manifold
Any obd0 MPFI ecu
Manifold
Distributor from the si, ex or hf. DX got the shaft here
SI harness
Old Dec 21, 2006 | 01:44 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (guy_from_nerk)
http://www.angelfire.com/d20/h....html
Old Dec 21, 2006 | 06:36 PM
204E-EF6's Avatar
well pretty much the 92 sohc head comes with everthing from the head up but no ecu and harness,even comes with axles, i guess nobody has a how to step by step on how to do this swap,from a d16y7 block with a d15 harness already hooked-up
Old Dec 21, 2006 | 10:58 PM
1991hb's Avatar
check out this thread https://honda-tech.com/zerothread?id=554053
It is putting a z6 head on a b7 block...pretty much the same thing you are doing. Very detailed
Old Dec 22, 2006 | 12:26 AM
nickeynick's Avatar
the swap is really easy. DPFI to MPFI like 1 hour with a soldering gun and some heat shrink. OBD0 to OBD1 just build your own conversion harness. buy a p28 ecu and you're done. i finished my mini-me last month!
check out this link...tells you how to build your own conversion harness.
http://www.geocities.com/kurtsi_on/page8.html
Old Dec 22, 2006 | 01:07 AM
davens's Avatar
Default Re: mini me help (nickeynick)
You're telling him its going to take an easy hour for a MPFI swap/obd0 to obd1?
And you wonder why people complain about the nosedive in reliable/quality tech answers around here.
Old Dec 28, 2006 | 03:25 PM
nickeynick's Avatar
Default Re: mini me help (davens)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davens &raquo;</TD></TR><TR><TD CLASS="quote">You're telling him its going to take an easy hour for a MPFI swap/obd0 to obd1?
just an hour for the dpfi to mpfi the obd0 to obd1 wiring takes a bit longer...a lot longer if you build your own harness.
cgross
Dec 18, 2012 06:52 PM
pimp4eva51
May 5, 2010 01:18 PM
EFstyle
15
Apr 19, 2008 05:02 PM
egturbo
Nov 3, 2004 02:43 PM
projectcrx
21
Jul 12, 2002 09:27 AM
