a6 or y8 throttle body
i am swapping a y8 head onto my a6 block. i have the throttle body for the y8, is there any benefits to it? or can i use my a6 with same performance. just wondering! I searched too
-map sensor on the throttle body
-55mm vs. 56mm if i remember right.
You have it so you might as well. It's probably not going to be a noticeable difference but you get a sensor off the firewall and a slightly larger throttle body.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy »</TD></TR><TR><TD CLASS="quote">from what i could remember, the bolt pattern change after 92 but i could be wrong</TD></TR></TABLE>
can anyone verify this? i would like to not have to really swap them out if i dont have to. i am not worried about a 1 mm bore difference or getting a wire off the fire wall. i have given up on trying to make my engine bay look pretty. thanks
thats wrong i had a a6 tb on a d15b7 not sure about the 96+ though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed666 »</TD></TR><TR><TD CLASS="quote">As far as I know an A6 TB will not fit on an intake mani off anything 92+</TD></TR></TABLE>
I'm pretty sure the same. I know my a6 throttle body wouldn't fit my y8 mani and vice versa. I forgot about that in my above post.
Correct, the D16A6 throttle body will not fit on any other intake manifold other than it's own and the D16A1 one.
Ok, here's the deal.
88-91 D-Series = The odd flange out, largest TB = 55mm
90-01 B-Series = The good Flange
92-00 D-Series = The Good Flange, largest TB= 56mm
H-Series + F-Series = The good Flange.
i dont want to make a new thread if i dont have to, so i will bump this and ask if my a6 headers will bolt right up? i dont even care if i lose performanc ethrough them, just want to drive the car with the head swap whenever i do it in the spring.
ATLien6
Jun 2, 2012 01:53 PM
simplegreenmachine
16
Apr 28, 2005 04:54 PM
