question bout b18c5 in a rex
Old May 12, 2002 | 07:02 PM
Motor-Tek's Avatar
Default question bout b18c5 in a rex
can i turbo a b18c5 in my rex?? will the turbo fit or will i have to modify my engine bay??
-jason
Old May 12, 2002 | 07:04 PM
EP3_05's Avatar
Default Re: question bout b18c5 in a rex (superstreet02)
It will fit depending on the mount kit you choose to use. You will also have to modify the front crossmember to clear the downpipe. Depending on the compressor size and manifold design you might have to shave some webbing off the block to clear the compressor. You will also have to modify some areas in order to run the charge pipes.
Old May 12, 2002 | 07:28 PM
Urban Business
Guest
Posts: n/a
Default Re: question bout b18c5 in a rex (91civic)
use the hcp mounts. puts motor really far back in engine bay. you will want to lower the compression of that motor tho w/ fi. might as well do a gsr turbo instead. much cheaper.
Old May 12, 2002 | 07:38 PM
Motor-Tek's Avatar
Default Re: question bout b18c5 in a rex (TorteX)
no, i don't care bout the money. So then it is possible right?? would my car be able to be street drivien w/a built jdm b18c5 w/turbo and nos??
-jason
Old May 12, 2002 | 07:44 PM
Urban Business
Guest
Posts: n/a
yes. but a built up b18c1 may be cheaper. do some compraision shopping:
B18c1 9.5:1 c/r
itr valve train.
JE pistons
eagle rods
itr intake cam
skunk2 intake manifold
aem pullys
lightened flywheel
or
B18c5 9.5:1 c/r
JE pistons
eagle rods
lightened flywheel
aem pullys
keep in mind your itr motor is like 1500 more but itr parts are more (usually) than gsr parts. shop around.
but yes an itr turbo will work
[Modified by TorteX, 10:52 PM 5/12/2002]
green_eg_hatch
Dec 22, 2009 12:14 PM
PIMPROB
Nov 27, 2006 01:24 PM
downtime1
Nov 26, 2006 12:32 PM
Speed Infliction
May 31, 2006 11:18 AM
EfSedanLove
Jul 21, 2004 05:48 PM
